Jump to content
Fitting G-Laderseite ARB Blocks
GiorgioGT
Recommended Posts
2 small screw drivers. they just prise apart.
stick them in the holes and pull them in opposite directions. like a X shape.
Link to comment
Share on other sites
I'm SORRY BUT THIS IS A 10 MIN JOB!!!!FIT AS REMOVED BUT IN REVERSE ORDER.
you sound like a haynes manual.
Edited by GiorgioGT
Link to comment
took me about 30mins tbh. prising the arb forward enough and holding it while trying to put the bolts in was the hardest bit, then seeing that the strut brace slightly fouls it, so that hole had to be made abit bigger.
Link to comment
I'm having these fitted to my car tomorrow! Do you think it would be a good idea to use a ratchet strap from the ged's brace back onto the arb to move it forwards?
Link to comment
that was what i did......make sure you jack both wheels up
Link to comment
can the arb be bolted down in the wrong place ie too far over one side? Before it could move slightly but with these new blocks and clamps its cant move at all.
Link to comment
If it's too far to one side, your steering wheel will be crooked, and you'll very quickly get feathering scrubbage on the shoulder of a front tyre.
Surely you only put the polomint clamps once it's settled into place.
Final tightening of the green clamps once lowered ground then drive or push
twenty feet forwards, twenty feet back, full left lock, full right lock, check nothings come loose, then forwards and backwards again and see if it gets back to the same spot.
Then fit the polomints.
That's my plan. And then I'm taking it for wheel alignment.
I'm putting my polomints on the outside of the green blocks as there's a bend in the bar where I hoped to put them on the inside.
Link to comment
Guest sooped_up_g
You boys have got it easy I'm changing the TCAs and the entire anti roll bar at the same time! :lol:
Thats what I've just done, its mental how much tighter my arb is now! My TRA's must have been shot!! well i had a bent caliper carrier as well so i reckon the car has come in to contact with a kerb at some point!!
I do love finding things out about a car when you pull it apart!!
Chris
Link to comment
:ninja: Why do you think I'm changing my TCAs and anti-roll bar :lol:
Link to comment
whoops
Link to comment
Guest sally_healey
^^^^^^^ lol
and I'm dredding fitting mine now... ahhhhh lukin at it though it really dus luk easy! :nod::paranoid:
It is, and that's coming from a GIRL :lol:
Edited by sally_healey
Link to comment
Is anyone else painting these before fitting?
I've just been doing mine with a brush and hammerite smooth metal paint.
I've done the 2 plates, main 4 bolts and the circle clamp things - and will just proper grease all the bolts before fitting...
Do with think the doughnut ring bolts heads will need treating?
Dave
Link to comment
I've painted mine with chrome effect paint because I'm a dick.
lol - good effort...
It looks like i'll be leaving these to dry and then have to do a second coat so probably wont be going on until next weekend and the latest...
Link to comment
i got all the bolts and plates zinc coated before fitting. cost me all of a tenner too. theyve been on since christmas and arnt rusty still.
Link to comment
^ Sounds like a good plan. I just found a left over can of chrome effect paint from when I was building my bike and thought I'd use that. Zinc primer and then the paint.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
