fitting 6n angel eyes
hey, well my angel eyes finally arrived, but i have no idea to fit these on a polo 6n, i get the 2 plug in sockets bit but theres 3 sets on red and black wires coming from each headlight, where do they go and how do i fit them pplleeaassee lol i can get pics if thats better?
many thanks
  • Replies 11
  • Views 4.2k
found this. theres the wires at the bottom.
many thanks.
many thanks.
I've got a 6n2 straight forward for me just plug in for 6n might want to try searching this forum theres loads of posts on this
not really helpful lol, the plugs are straight forward but the red and black wires have no plug/connection on them to fit to the polos wiring, so again i must ask help pweaseee :)
each pair of red and black wires are the power supply for each halo ring and each little LED cluster in the corners
the outer most pair for the outer halo, middle for the inner halo, and inner pair for the LED cluster, just wire each pair wherever you want really, the red wires are positive, and black are negative
on my old car, i wired all the blacks (negative) into the earth wire for each cluster (brown on the cars loom), and the reds into the sidelight wire (white or yellow i think, but arent tooo sure, can check in haynes tomorrow)
sidelight is a thin grey/black wire :)
the sidelight wire on the cars loom is grey...
yellow is dipped
and white is hi-beam
rrriigghhtt lol so am i right in saying
wire all red and black wires to the grey wire??
that way when sidelights are on so are both halo's and led and also they will stay on with dipped and main beam that right guys?
ok guys before i start 2moro am i right in saying
*wire the positive wires to the sidelight wire (grey)
*wire the negative wires to the cars earth wire (brown)
but we have hit a problem! the socket from the headlight dosent fit the cars
standard socket, so I'm assuming i need to hard wire it after halo positive wires
are done and negative wires are done, where do i wire the
2 remaining wires to (white and yellow) theres 4 wires from the headlights
(red,blue,2 black wires into 1, and a white wire)
that make sense guys?
Edited by tommy_boy
i will paypal the 1st person to tell me step by step what to do correctly a fiver, i need to get these lights on now, so can anybody help for a fiver drink?
right, theres two things you can do here, i'm guessing the halo's have a bigger plug than your polo? if your polo socket only has 4 pins then you can pop down the scrappy and try and find a polo which has the bigger sockets, the bigger sockets are for polos with headlight adjustment...
but iiiif you want to just hardwire the lights in...
blue wire from headlights to yellow on car loom
that single red from headlights to white on car loom, that other white wire from the headlights you wont need
and all the little reds from the bottom of the headlights to the grey on the car loom
and then ALL the blacks (including the 3 from the bottom) from the headlights to brown on the car loom
hope that helps mate
thats brillent dude, its going to a mates garage 2moro to do it properly as I'm ok with it all but rather safe than sorry with electrics,
cheers again matey!!!!!
