Poly bushes
Now an official supplier of super pro polybushes, they are an excellent addition to any suspension mods, stiffens up the front end a treat. Prices for the mk1-3 polo poly bushes are as follows....
Front lower arm set, inner and outter (both sides) - £65
Anti Roll Bar to chassis - £20
All prices are delivered.
Can be fitted at my workshop in Surrey, just give me a PM.
  • Replies 45
  • Views 18.7k
  • The issue with powerflex is the design on the outter lower arm bushes causes them to tear to pieces within a couple thousand miles. Thought it was only on G40s untill a mate with a coupe s did a set o
are the prices posted??
lol thats what you get for not reading the post properly :retard:
have you used them yourself??
are they difficlut to squash into the arms??
I use them, the antirollbar bushes are really easy to fit, the ones in the arms are going to require a vice, or you can just stand on them :)
The TCA bushes are split for easy installation...
can you get ahold of the rear axle bushes? i have power flex on the front but cant find any rear ones?
chers
gaz
have you got a full set for a mk2 polo saloon 1986?
I have the front wishbone & anti-roll bar set fitted. There is a noticable difference, and well worth the money :)
I doubt they'll be of much use to you, as they are already fitted. Out of curiosity, why do u need to see pictures of the bushes fitted?
Does anyone else sell rear end polybushes other than g-lader(sp) onees?
Cheers Arran
Will grab some pics next time I fit a set.
No where does poly rear bushes other than the g laderseite ones.
But if anyone has a spare rear axle they fancy chopping one end off where the bushes sits I'll sort them a free set (might be a good 6 months though as they've got to go back to the manufacturer. I haven't got any spare axles about to do it...
  • 5 months later...
is this all i need to replace my bushes in a mk2 saloon? cheers
Better than the powerflex, as they have a ridge on the outter tca bush where the arb goes through, and with some serious driving, it'll rip to pieces. I did a set in 1.5k miles in a G40, think emdee holds the NA record at 3k. haven't done a set of these yet....
Yep thats all you need for all the bushes except the inner steering and rear axle bushes.
Any photos of these fitted to a Mk1
Cheers :-)
  • 3 months later...
ok people -
i ordered these off phil ( the full kit £85 ) and they have made a big difference!
for anyone interested in these my advice would be to buy them :-D
i have uploaded some pictures fitted to a 1993 polo coupe - these will fiit any polo mk1-mk3.
i wanted to do a good job so i also brought 2 new wishbones from my local part store ( £28 each ) and did everythng from fresh
make sure you get your wheels aligned after job
you can see them in the picture- inner, outer wishbone and anti roll bar bush. they are dark purple in colour
thanks phil for sorting them out - fast delivery and dispatch too :thumbsup:
:-D
Edited by koolspot
Cheers for the pics.
Is there a front upper kit??
There isn´t any bushes in the upper? Apart from the steering arms and top mounts, but no one makes these...
could you look into having a set of steering arm ones made up?
It could be in the pipeline indeed, would be usefull.
Am I gonna have to go too a garage? Need some sort of compressor to get the wishbone ones in?
yeah you can use a compressor/compression press or a simple vice clamp.
steering bushes would be a good idea
i would defo be interested in a set and a set or rear's
