Nearside rear spring is not broken. I put the car high on an axle stand so the rear axle can pivot and the spring extended fully. Dust cap still on. No broken coils. More tightly wound at the bottom and top. Used a jack to compress it upwards, then released and it descends very slowly. Too slowly to absorb a bump I reckon. Found a piece of hard round 0ne third circle of black plastic inside the spring. Top of a gas shock? -
