unsure about the bhp of my car :S
i own a vw polo 6n 1.4 16v and i have always belived this to be 100bhp, how ever as I've been searching for an airfilter I've seen alot of places saying that they did a 1.4 16v in 75bhp is there anyway of telling without putting it on a rolling road?
p.s could any one reccomend a good reasanble induction kit
cheers, levi
  • Views 1.4k
I think all 6n 1.4 16vs are 100bhp, 6n2 1.4 16v are usually 75bhp. Where it gets complicated is some companies including VW call 6n2s 6ns so its best to just check the year of the car its for.
Best induction kit to buy if you're after performance gains, would be bmc cda they're about £130ish.
If your just after the nice raspy sound, you can get K&Ns - £60ish, or make your own - all you need is: some silicon hosing (you'd need to check the throttle body diameter to get the right size hose), a universal cone filter, a small oil breather filter and a cold air feed. All of which can be found on ebay or most of it in halfords and should cost more than £30 for the lot. :)
Look in the boot for the data sticker that will give you the engine code, it might also be on a bar code sticker on the cambelt cover, from this you will be able to find out what power you have, the 75bhp ones only started to be fitted from around 1998 but the 100bhp went from 1995 to 2002
AFH, AFK & AUB = 100BHP
AHW, APE & AUA = 75BHP
cheers mate, very helpfull ill think ill go for the K&Ns if they give a sound improvment, as i only have a standard exhaust,
cheers bud ill go have a look
just checked and it says AFH :)
K&N with standard exhaust will give a nice sound. Not noticeable when your sitting in traffic but when you put your foot down past about 3000rpm will sound nice and sporty :thumbsup:
