Heater Blowers/Fan
Mine stopped blowing a couple of weeks ago, i replaced the fuse and it was fine again. But two nights ago it went again, so i replaced the fuse but it won't work at all now. It's heating up, i know that but just the fans aint working!
Anyone know where to start diagnosing this?
  • Views 2.4k
With a good fuse in place will it run on setting #4? if it does and not on any of the other settings your resistor pack has burnt out, it's mounted on the fan unit, easy to replace
I've tried 2 x 20amp fuses and neither of them worked on any setting.
Do GSF do the resistor packs? Also where is the fan located?
If it's not working on any setting either the switch has died or the fan itself, the fan is under the dash passenger side, it makes it easier to access it if you remove the glovebox (six screws), if you remove the pollen filter from under the bonnet (unclip the rubber trim along the rear of the engine bay then lift off the plastic trim) you can see the blower fan and see if it's seized!!
Eurocarparts list two blower motors £185 or £109!!!! GSF do'nt seem to list them and neither list the resistor module!!
My fan went back in february, so I took it into a local garage, they quoted me £250 for new parts and 2 hours labour!!
So I went down to the local scrappy, got a new fan for £20, bought a new resistor off ebay for £11 and fitted it myself. Took me 10 minutes, no joke.
If I were you i'd buy a new fan mate, like mentioned, the fan is above the passenger's footwell. No need to take out the glovebox/airbag, just pull down the foam sheet protecting it. All you have to do is unplug the fan from the resistor, push the clips on each side of the resistor which then slides out of it's slot. Then undo the bolt connecting fan's earthing wire which is on the side of the car next to the fan. Twist the fan from the base and it will unclick and drop down.
Then all you need to do, is source the parts and do the reverse of what i've said to put it all back in.
If you need a guide or something, I have pictures on my phone and i'll explain it more thoroughly if you need it...
Oh and the resistor is right next to the fan, you'l see it as it's the thing that has the fan plugged into it and also the wires from the heater controls.
Hope this helps
Instead of a new thread: my fan works but no heat, just a bit warm. Then what?
Does your thermostat open properly? I.e. when the car has been running a while does the bottom rad pipe get hot? Does the guage in the dash read 90 after driving for a while?
Dan
Checked all the hoses, they all hot. car is heating up in no time stoppes at 90.
when it's extrmley hot in traffic jam fan works fine.
has nothing to do with the case but a/c is freezing.
fan blows well... i was thinkin maybe the handle switch for the temp is gone but
when on a/c and you turn it to warm it becomes breezy but not cold.
so maybe there's like a guider for where the air comes from which is faulty?
have to take out the dash prob...
