Mk2 Polo Coupe S Buying Guide?
Hi everyone, am new to the forum. Been reading it for ages but only today decided to join, well done its a very informative/friendly forum. Have a big favour to ask which is some advice as I want a mk2 polo coupe, fell in love with these when i was in wolfsburg a few months ago.... have been looking at some of the threads looking for info on the mk2 polo coupe but am coming up short am in particular interested in a coupe S due to the different interior etc..... Have plans for one (bbs e30's, berg cup arches,etc etc) but for the moment I want a reliable base.
Hope I'm not going over something thats been covered already so apologies if i do :lol:. Just looking for some buying advice, have lots of questions and if anyone can answer one or even two that'd be great as i dont expect anyone to answer all.
Reliability: How reliable are these cars? Think the coupe s comes with a carb 1.3 engine, if the carb is left alone how reliable will the car be on long journeys as i will be driving 4 or 5 hundred mile trips bi-monthly with it. If though the carb has been changed or touched how awkward a job is it to get right and does the choke on these really give that much trouble? Know there may be other problems but i gather that they would be stuff that'd happen to any other car
Bodywork: Gone through a few mk1 golfs and a mk3 polo which was surprisingly rusty so i have been burnt enuff to know to look very well for rust, just wondering if the mk2 polo is prone to it much? And if it is is there anywhere in particular it really sets in? In passing id heard a problem with apparently all the polos up to and including the mk3 is the chassis legs cracking? Should i worry about this and how can it be spotted/prevented.
Electrics: Anything i should look out for?
Trim/spec: As above am looking for a genuine Coupe S. Are there any out there which have the sticker but arent a genuine S? Couldnt find any information on a definite spec of the Coupe S, anyone have an idea? Know some of them came with a tartan interior but my knowledge ends there.
Performance/Mods: Does anyone know the genuine output of a coupe 1.3? Would they be about as quick as a single point injection mk3 polo? Do mk1 golf callipers bolt straight on and would they make much of a difference?
If anyone can answer any of the above it will be very much appreciated or if there is anything i left out that i should know, by all means enlighten me, thanks guys and i hope to do the forum proud in the future 8-)
  • Replies 31
  • Views 10.4k
  • If your planning on doing the berg arch thing your going to have to butcher the arches all round to fit them so I wouldn't go for an emaculate example. Watch out for rotten fuel filler neck down wh
Watch out for rotten fuel filler neck down where it is splashed by road salt as it means new tank, again if your going to be welding up the arches properly for bergs then it's a tank out for safety reasons.
Check the battery tray, very common rotten area under the battery.
You get rot under the arch trims but again... (you get my drift)
I would just get a fairly clean polo c and upgrade the engine with a GT or G40. If you do get a 1.3 then people have fitted twin carbs for performance..
As for coupe s it really is a trim level so again you can mix and match interiors second hand/scrappy finds etc. I think it might have a better bottom end than say my MH engine.
The engines are pretty bomb proof as standard as long as they are serviced. The pierburg carb can be troublesome in the colder months but plenty of info on here with advice on conversions with carbs. The mk3 is essentially the same motor with face lift and injection added. There are different bottom ends available in both mk's but now I'm not the one to ask and I would suggest spending some time on this site's search engine...
Oh and you ideally want a five speed for longer journeys although the four speeds are ok but if you upgrade to a gt you'll probably be fitting the 5 speed along with it..
Other folk can add or correct what I've given you so far....
Check this as a starting point:
http://www.clubpolo.co.uk/forum/index.php?showtopic=12474
Oh and welcome to CP
Edited by MacColl
chexk the carb runns well they normally come with a peirberg, they are wank, so think about getting a webbe :)
lol at the above post
a pierberg i would say when set up correctly are better than a weber in terms of fuel consumption and reliability sake. Why are so many 20 year old polos still running without engine rebuilds.
a weber 32/34 dtml will give you more power, and better fuel consumption than a pooberg thats running like a bag of shit.
mk1 golf brake upgrades and indeed teh std brakes will fit straight on
itll say coupe s on the logbook and data sticker in the boot if its a genuine coupe s, they have 55 bhp lumps, either 2G or MH lumps.
top cars, practically bullet proof and reasonably nippy. I've done 5k faultless miles in mine in less than 3 months only things that really need replacing was on the running gear side as many of the original rubbers had perished or cracked, replaced it all with a full subframe and wishbone conversion, g-laderseite bushes, hnr cup kit and g40 steering arms, tcas and damper and the car is a completely different animal handling like it should have done out of the factory, I've annoyed a few people doing 50 round roundabouts and very tight sweeping bends
:nod:
Had mine setup in my huge service inc vacum hoses and other bits around it. Starts first time everytime, idles properly and runs great! More reliable then the Golf tbf.
brilliant cars , used to do a 1000 miles a week in mine , and that went for 5 years , no carb probs , no gearbox probs , did have to put an engine in it because of my high miles , but overall the best car i`ve owned , rust can be a worry but mk2`s are better than mk3`s , my a plate coupe has no rust under it at all
Performance wise in my view there about the same as a SPi mk3,
Mines solid underneath but seems to have rusted around the bumpers, i hear thats common
Iv got a weber carb so i carnt realy comment on that
I think if I'm right the have the pin striping along the sides, but i dont know if thats on all coupes actaully,
Plus mine has red trim around the clocks, once agen I'm not actaully sure if they all have that
I find the mk2 is more reliable than the mk3, just dont look as good:(
Thanks for all that information everyone, nice to see that not everyone has problems with the carb . Sounds like i don't have much to worry about, had heard alrite that they are built better than the mk3 polo's.
@ MacColl not sure bout the g40 or gt engine, if i were to go down that route wouldn't be for a good while though i do like the thought of a 1.6 16v.... not that id have a clue how to do it but a cool idea. Yeah will have to do lots of arch work to fit the arches but i already have the E30's and they are a pain in the behind to put together so i might as well go the whole hog and make a berg cup imitation of it.
Thats pretty much all i needed to know, though was wondering about getting the carb tuned? Is this an awkward job is a carb a carb or would you need to go to someone who knows these cars and what mpg do you guys get out of yours? Never had a car with a carb so excuse me if thats a bit of a simpleton question...
Thanks again lads
With carbs it's a matter of someone (usually some old skool geezer) with the knowledge and a rolling road to get the right jets set up with fuel mixture etc. for specific requirements.
I have a twin choke weber fitted to mine but have made little attempt to look at set up till I get a less restrictive exhaust and a better inlet manifold. On top of that engine porting will give more performance if you know what your doing.
However there is loads of info pinned in the engine section for carbs especially the weber twin chokes which are very tunable and the path has already been made by many a person on here often leading to twin webers or bike carbs...
I couldn't even drive 4 years ago and now because of this club am able to do 99% of the work on my car.
Edited by MacColl
The coupe S,which carries the GT identification on the body (sticker in boot and code riveted to front panelwork behind front grille),had a revamp in '86 which gave it a blanket of small differences but most notable was bigger front brake calipers,electronic ignition,5speed gearbox,hydraulic tappet cylinder head (MH then 2F,exactly the same 1.3 engines as other trim,actually less powerful than the pre-hydraulic HH engine) and a pinstripe tartanesque interior.
But these later shells rusted worse than the earlier ones - particularly the rear sills,rear jacking points,rear chassis legs where the beam is attached and the rear seatbelt lower mounts/panel,front and rear arch skins,where the rear plastic arches are riveted to the panel,box sections directly behind the back wheels,inner panel around the petrol filler pipe,and petrol tank filler pipe itself.
I used to travel from Bucks to Aberdeen and back in my first S,and the carb only gave me some minor icing issues north of Kendal. But another S gave me no such issues on its only occasion up there (I've owned several Pierburg engined '80s VW's,and only got icing from one,and notably poor economy from one other).
The rustiest ones I've seen were 'D' registered,first revamp cars - a monumental deterioration in metal quality shared with other european manufacturers at the time.
Not all later S's got sports seats - mine has S fabric on standard seats.
Still red instrument stripe,tachometer,sports wheel etc. If you sit tall,avoid the sliding sunroof - it was the only thing i didnt like about it with the previous bodyshell (mine is re-shelled). Forget mileage,condition is everything.
And in my opinion,the car feels best on 13s,and the 1.4 ABD is the best engine block to fit
(also a straight swap).
Damn pity i had to get rid of the mpi mk3 i had then engine and box were perfect wudda cost me nothing to do the conversion but my time, ahh well.
Didnt realise that they rusted quite that much, will actually be driving up around that area of scotland, how did you solve the icing problem when you had it? A hairdryer and crossed fingers? lol thanks for all the info lads is priceless. Wont ask anymore questions about the problems inherent to these before i get put off lol though i do have one last question. I see on another thread that a guy from on here has been absolutely fu**d over by some ill informed small p***s pr*k with a uniform.
Would putting the berg arches on the polo be the same as say putting arches on a mini for wider wheels? They will be approx 9 x 14 but will be within the extended arches, anyone see any problems there or is it 100 percent legal because its within the bodywork albeit modified bodywork. thanks
carb icing is annoying but not the end of the world, usually a 2 minute spell with the engine off and the cars reet again. its more prominent when you dont have a hot air hose coming off your exhaust manifold that goes into your air box, the warm air really is needed on long journeys in the cold, once i replaced my tubing and me and karl bodged the manifold heatsheild back on I've never had the same issue again
you shouldnt have a problem with wide wheels and berg arches as long as the entire wheel sits within the arch, if you have any part of the wheel sticking out (regardless of whetehr the tread line is within the arch) you will be in a grey area in terms of coppers and whether or not they pull you would be at thier discretion
my dads old jag xkrs rear wheels used to stick out a bit but jag got around the legalities by putting a small arch spat liner thing that protuded outside the arch slightly ensuring that the wheel was behind cover
Thats very good, was thinking it wouldnt be a problem but nice to hear that it shouldnt be. Yeah i see lots of vehicles do that alright 4x4's in particular, will steam ahead with that idea so (as much as i can without having the car ) lol Thanks for the icing info, read up on it and is something id never heard of as have only had injection cars, but sounds like a tiny problem really.
Hope I'm not asking too much of everyone but i was reading through a thread about engine conversions and i am more confused now than when i started to read it. From what i have read you can put 1.4 blocks on the gt engine and mess around with the head.
My question is this though with regard the 1.4 16valve from the 6n polo specifically. If you bought a complete donor car and were willing to swap the entire wiring loom if needed then what problems would you come across fitting everything in? I have read there would be a problem with brake servo and bulkhead? Is the bulkhead problem the exhaust? As i would be able to get a custom manifold knocked up handy. Also a problem at the front with regard a mount, thanks for the help everyone :-)
The icing was probably due to a home-made cold air feed id fitted,using 80mm flexi tube and a stainless mesh filter at the grille :grin: But i got around the problem by fitting bike carbs - which do not ice.
The rust varies. If you're looking at pre-'85 cars you've far less to worry about - worn/rough trim lets the earlier ones down,any rust should be minimal.
And my list of what rusts is where to look,though i did find the lot gone on a couple of S's - still,dont dismiss the remaining later cars as rotters,as the bad ones are pretty much gone now.
The nicest one i saw,about three years ago,wasnt even an S,but a white 1.0 hydraulic model with light grey interior. No rust at all,i dont know what model it was,just a coupe with white bodykit and white twin lamp grille. What it was doing in a scrap yard i dont know,its a shame so many good ones were needlessly destroyed.
Your questions list will only grow,but its all here in the relevant forums - from tubular exhaust manifolds,what seats fit,upgrading/enlarging the S engine,fitting alternatives,brake upgrades,choosing gear ratios etc etc.
But just to clear up the engine confusion,any 1.3 hydraulic head,from a standard '87 to a '93 GT,will bolt straight onto the 1.4 ABD engine from the MK3 Golf,and the ABD block bolts straight into the Polo. The head is the same anyway.
But dont get the 1.4 from a Polo,as they're different - and with all post-'94 Polo engines,there is the engine mount problem,fuel system compatibility problems,just problems.
Thats great thanks for clearing that up because i couldn't get why nobody was taking the hand of people for all those cheap polo 16v i see selling. A bit of research into how you can mate the gt or s engine to the 1.4 block and carbs is the order of the day for myself then. Will look into it myself as i know I'm taking the piss asking all these questions when the stuff is there already. Just love these cars, would you believe id been looking at them on the internet for years but the only time I've ever seen them in the flesh was in Germany.......
Wont get a rusty one and thanks for telling me where to look, been burned before and i know you cant always spot all the rust but trust me i do my best to do so, last mk1 golf i bought i spent a half hour underneath it, no joke.
What kind of power are you getting out of your own engine with the 1.4 block and bike carbs? I assume you used bike carbs to avoid having to convert to injection for a gt? Would your car take on a g40 say?
where should we look for rust on a coupe s ??
i wanna give mine a check over
MikeyMK listed out the parts that rust most commonly at the top of this thread about 4 posts down. Much rust on your own? hope you dong find any
everywhere :lol: use your eyes boy
i can't fined it
and there doesn't seam to be but i just wanted a list of where to look
LoL
can you just let me know where the mk2 problem areas are please
no offence brendan, but learn to read properly and use a spell checker
were not here to do your legwork
Lol , I was just about to say how good a thread this has been for good no bullshit info on mk2's (which it is)
Just one other thing which might be relevant is the build quality of the earlier German made cars being better (I think up to 86 but don't quote me on that) I mean stuff like the accuracy of the underseal and stuff like plastics (they have made in Germany written on them). This has nothing to do with engine work mind. Sorry MikeyMk has kind of touched on this with the rust.
I've been stripping an earlier car for spares and I'm convinced the overall build quality is better than my spanish made 89 square. Of course this can be outweighed simply by the fact that the older ones are getting on for over 25 years old and long in the tooth. What I would say is I've eradicated all rust from my car anyway and cavity waxed it where the sun doesn't shine.
Finally thanks for asking some good questions in the first place.
Edited by MacColl
Wont get a rusty one..
I very much doubt you'll get a completely rust-free one either.
Yeah,initially i was gonna use a single Pierburg carb from a 1.8 Golf,didnt have to be so fast,but the manifold didnt fit. I spoke to someone with a V8 Capri who had alot of experience in fuelling conversions,i asked about injection,and he suggested bike carbs. I looked into them and realised i was really onto something.
I've never put either engine on a rolling road (its now a 1.6).
Any Coupe S is going to be at least knocking on for 20 years old now, so all but the very best will have some rust, but have generally fared better than other cars of the era as VW rustproofed most of them well. Check any car over well for rust, but particularly the following:
Colour is a big factor: Light colours, particularly silver are more prone as they have thinner paint than darker colours such as black, metallics, and never rust navy (so called because the paint on mk2's this colours is about 9 inches thick :unibrow:).
The main reason for rust is the sill and arch kit getting moisture stuck behind it. It'll show when it's getting bad by creeping out into the visible bits, but before it gets that bad, it's worth taking the kit off and having a look.
Round the windows, particularly the rear quarters and windscreen can be bad, as water tends to sit here. Don't let your scuttle start rusting out from this, as it is a mare to sort out. Likewise, look round the wiper arms.
Battery trays don't tend to be bad on mk2's, but have the battery out and take a look anyway, just in case a battery's leaked, or the drain hole's become blocked. Anything worse than a small patch in this area is a tricky job.
Tailgates can end up rusting from the inside, this is normally because of the rear screenwash leaking.
Like any car, they're affectted by stone chip damage, this is unsightly, but unlikely to get bad unless left unchecked for long periods.
A big concern is the fuel filler neck, as mud can get stuck here for long periods of time and rust through the neck. Check the back of the sill round here well as it suffers at the same time.
Age of car is also a factor, the early ones were built and rustproofed better, though being older, these won't neccessarily have weathered better.
thanks Yeti
what a mk2 coupe s wroth ??
How long is a piece of string?
