Buying a Mk2/3 coupe hopefuly...
Hi there, I'm hopefully going to be buying a Mk2/3 polo in the next couple of months when I come into a little money and should, I'm praying, have a full drving licence. This is providing I can get a decent insurance quote a good bit less than half of what I'm getting at the moment (Around 4 grand).
I was just wondering, is there anything I should be looking out for problems wise besides wheelarch, battery tray rust etc, cold/hot start up and all the usual stuff? Could someone provide a small buying guide? :-)
Note, this will be my first car, and although I think I know alot about cars and hope to do an engineering degree or work somewhere in the field, this will be my 1st experience buying, owning and working on a car.
I'll probably be limited to a 1.0 by insurance, with no mods for a bit.
Edited by Duffy1207
  • Replies 15
  • Views 2.2k
Just bought a 1.0L MK3 Coupe myself, Cheapest insurance qoute i ahd for a just passed at 17 was 1200-1300 with Breakdown cover, this was with Adrian Flux who also offer club discount and wasnt included,
Places id watch for rust are the bottom of the doors mine has a little but only surface - Thats alls i know :)
Thanks, all help appriciated.
I'm going to try phoning a few places and speaking to actual people rather than letting comparethemarket do if for me, so I'm hoping the quotes will be much smaller.
Generally, Polo's are well built reliable things?
Anyone else?
Just make sure its been well serviced. If not, they can be right lil pigs to sort out.
Another place on mk3s for rust is around the rear screen as the water settles in the groove around the glass and rusts it out!
*awaits Hayesey and his bible brain of polos to appear*
Haha, Mine got little rust, will be sorted out for Next year, when I'm going to shows
Yeah Phone the insurance companies, i was getting 2-4 K Qoutes then Direct Line Give me 1400 Across the phone then i got the Adrian Flux one, Also try Brentcare, i havnt tried them yet :S
look for rust everywhere nothings harder to fix than a rotten car , take a torch and look everywhere underneath it
make sure the oil light goes out on start up
check it idles smooth both hot n cold
listen if the gears crunch
oil leaks around the left front side of the head are very common , fairly easy n cheap diy fix , but worth haggling some £££ off if its leaking
Yeah, the oil leak IS common. Don't think I've had a mk3 that hasn't had a small leak there.
Thanks, I'll look out forthe oil leak, but guess its either not worth fixing or easy to do?
Gonna try ringing up some of the insurers I've heard about on here and see what I can get, hoping lowww.
Any ideas on mods I could get away with at 17/18? Would like a set of 13" RA's or something?
you will proboly find that any mods are going to be expensive on your first years insurance but you might be able to get away with alloys tho if your lucky 8-) but not much else :lol:
I'm not really thinking of having anything done engine wise, as I guess 1.05 probably won't respond brilliantly? A fahrvergnugen chip looks tempting from the feedback I've read. I assume you'd have to declare that if you had it. What's the power increase/driveablilty like with the chip, and how much would you expect the insurers to add on being 17/18 (Probably won't have car till I'm 18).
changing the side/front repeaters and a debadged grille shouldnt up your insurance too much if at all really.
Best to get any alloy wheels declared in case they go walkies!!!!
(10,000th post! way hey!)
Congrats on the 10,000 posts, I'm some way off yet.
Most I've ever got is about 350 on head-fi.
Anybody got anything to say o n engine mods for a 1.0/1.3 polo, or should I wait and get a GT engine, or indeed a GT after a year or so.
Most people check for new tyres. I'm not interested in how much tread they've got. Brand names are everything,and id rather see worn Continentals than new Superspeeds.
Its all about how the car has been looked after over the last few years. A Halfords battery usually means Halfords brakes,and i wanna know that the maintenance of the car was taken seriously.
As for rust,you only have to check half the car - the back half.
That's true, good tyres on the car indcates it was probably looked after and cared for, although I'd care for my car and probably wouldn't be able to afford good expensive tyres. Whats the going rate for a decent set of 175's?
yeah just check the usual arches for rust, especial rear drivers side where fuel pipes etc are, both my mk 2 coupe and the other halfs bready had it here, due to the amount of mud that gets up there, make sure that the gear box has oil in it when you first get one, no one seems to check this as its a pain to get to but it saves on crunching or sticking gears later on, and as said above dont be surprised with oil leaks. See if the cam belt has been changed aswell, Apart from that its just the usual to see if its been well maintained and looked after properly. As for insurance try direct line my other half was beeing quoted stupid figures but they quoted about 900 fully comp for a new driver with 1.05l so look to see if you can get a better offer fully comp, just watch out for how much excess you have to pay though.
