6n coilover info
ok so I've seen alot of threads asking about what coilovers are best, how much drop etc so i thought we could all come together and help each other out and maybe this could get pinned for future reference
so now i thought those of us who have coilovers could fill out some information about them using the following criteria
Make: Ie; ta technix, FK etc
Model: were a model applies
Height adjustment limits: ie; 20mm-120mm
Helper springs: Have you got them in Yes/No
Damping adjustable: Yes/No
Current ride height: how low are yours at the moment
Ride Quality: Extremely stiff, stiff but livable, firm, bit like a blamonge etc
Driven daily: Yes/No
Price: £???
Pros: what specifically do you like about you coilovers
Cons: what could be better, or what dont you like about you coilovers
Have you had any other coilovers? if so what where they and are they better or worse than your current ones (what would you recommend):
  • Replies 9
  • Views 2.3k
Quite a good idea, and I'm bored stiff, so why not, lol....
Make: TA Technix
Model: -----
Height adjustment limits: About 120mm
Helper springs: still fitted, low enough..
Damping adjustable: no
Current ride height: about 120/100mm
Ride Quality: Rock hard, bouncy and noisy
Driven daily: for now yes
Price: £200 ish
Pros: cheap lows
Cons: poor ride quality
Have you had any other coilovers? not owned but have experienced Weitecs which i found superior even when ran as low as the TA's.. but obviously you get what you pay for..
Make: TA Technix
Model: n/a
Height adjustment limits: 20mm-120mm
Helper springs: Removed from front still in on the rear
Damping adjustable: No
Current ride height: 100/90 (front/back)
Ride Quality: For me its perfect, very communicative, handles well rides well if driven sensibly
Driven daily: Yes (when it works)
Price: £200
Pros: cheap/affordable but still look like a quality product. Relatively easy to fit, adjusted easily and despite what most people say I think they give a pretty good ride.
Cons: Like with all coilovers they will seize if they aren't copper greased and maintained.
Never had any other coilovers but had TA Technixs twice now and both times have been great. I've seen people write on here about how they are terrible over bumpy roads and if you hit a pothole. But I've found an easy way to solve that...avoid the bloody bumps and potholes!
I'd say for general road use and maybe a bit of fun at the weekends TA Technix coilovers are more than good enough for those needs. I would personally only invest in a more expensive setup if I was tracking the car.
Model: n/a
Current ride height: about 80-90 all round
Ride Quality: Extremely stiff but livable cause i wanted it low
Driven daily: Yes
Price: £200
Pros: cheap and low
Cons: can be abit bumpy like incredibly bumpy :D
Have you had any other coilovers? if so what where they and are they better or worse than your current ones (what would you recommend): this is my first car so no first experience but i can live with the ride quality
if you wanna go low you have to pay the price of either more money or the ride quality.
Edited by Jaym
Make: Raceland
Model: 6N Coilovers (?)
Helper springs: Yes
Current ride height: 80mm drop for now.
Ride Quality: Stiff, but liveable
Driven daily: Yes
Price: £165
Pros: Cheap lows!
Cons: Materials, they need regular checks to ensure they don't seize.
Edited by deviance
Make: TA Technix
Model: For 6n polo
Height adjustment limits: 120mm max.
Helper springs: Out all around.
Damping adjustable: No.
Current ride height: Around 110mm at a guesstimate.
Ride Quality: Stiff but livable
Driven daily: Yes
Price: £120
Pros: Cheap, 2 year warranty and not had a problem so far.
Cons: Could be a better ride, but for the money, it's not terrible.
Have you had any other coilovers? I've felt Weitecs on a 6n and they are better quality, but more ££ = better ride.
nice one, some good info there any one else with any other coilies that ta technix lol, cheers guys keep em coming
bump comon guys what you running?? FK?? AP??? V-maxx??? Wietecs???
Make:FK
Model: silverline-x
Height adjustment limits: 30mm-100mm - figures apply with helpers in, taking them out would need chassis notch anyway.
Helper springs: Yes
Current ride height: guess at 55 - 65mm (still in bbs mode)
Ride Quality: Extremely stiff - when I have the RSs on I run on max stiffness as they rub on the arches at the slightest hint of a bump but as stated, they are adjustable so they could be softer if i wanted. I'm happy with how they are but compared to standard suspension they're bumpy as fuck!
Driven daily: Yes
Price: £703
Pros: fully adjustable
Cons: over priced for my requirents really, only the adjustable damping makes it worth it to me.
I'd recommend a cheaper set as I cant see them being much worse, also if you're seeing -90mm plus - ride will be pretty shite whatever the brand!
Also take peoples and manufacturers lowerage figures with a big pinch of salt, they're usually generous to say the least. We all know that sub 110 is impossible without chassis notches and anything sub 90 means driveshaft rubbing.
Make: AP Sportfahrwerke
Model: 6N
Height adjustment limits: ie; 30 - 75mm (apparently- think less if you take out the helper springs
Helper springs: Left mine in
Current ride height: 65mm
Ride Quallity: Quite stiff but apparently some of the most easy going coilovers for the money (does me fine for the 48mile per day commute)
Driven daily: Yes - done about 15,000 miles now
Price: £365 - Venom motorsport
Pros: Good quallity , well made , 2 year warranty , comfortable enough
Cons: cant really think of anything... I'm on 15" wheels so dont need it any lower....errrm they could be cheaper ??? lol
