Ecotek Valve ???
  • Replies 12
  • Views 1.7k
turns out ford and mercs use the same kinda thing
'' of merc website''
Tumble Flaps Improve Fuel Efficiency
The new-generation engine is also equipped with tumble flaps in the intake passages near the combustion chamber. The tumble flaps open under part load, improving combustion by creating additional turbulence around the intake valves and in each combustion chamber. During higher engine loads such as full throttle, the tumble flaps are completely recessed in the wall of the intake manifold. Better combustion helps improve engine torque, but the primary purpose of the tumble flaps is to further increase fuel economy, and tests show that the tumble flaps indeed boost fuel mileage by about two percent.
have a read of this clicky
thamnks mate. not sure what its teling me tho. i would have little affect on post '93 car s? mpg wise
what about performance.
bet its al bollocks
"In summary: even on cars chosen by Ecotek, with the CB-26P tuned by them and the tests under their overall control, they can only demonstrate tiny economy and emissions benefits on a lambda-controlled vehicle"
it does sweet fcuk all except make noise and make u £40 poorer
had one on the focus was pointless mate
the only good thing about it is if you want to take the piss is turn it too far and make it sound like a duck bill thing when off the throttle!
ALL it does is create an air leak and make the air/fuel ratio leaner. That's ALL it does.
If it works, your car was running rich and a remap or tune-up would be far better than using one of these. Anything else it says about the 'technology' (that's a laugh) being used on any cars, tuned or from factory, is bullshit.
I second everything Danny Lee said, they are an utter waste of time and money.
Had one on a Golf 1.8T don't work was better without
paul
A gimmick by sounds of it..
like that red cars go faster becuase of the light emmisivity of red paint being lower than others hence creating less drag through the air...
0.0000000000000001% difference obviously but technically an advantage :roll:
Complete waste of time & money!!!
all they do is make your engine bay looker a bit more impressive by having some kind of filter under the hood!!
but if you like the sound of a sheep farting then go ahead, as thats all it does...
also if you do as in the instructions and fit it to the brake servo, your messing around with the BRAKES!! not a good idea
