Horn push
Iv got a omp wheel and horn but my boss only has one wire ibplugged that in but horn dosnt work iv been told i need to earth the other copper electrode on the back of my horn anyone have any ideas ?? Where do i earth it to?
I can get pics if better :)
  • Views 1.2k
one goes from the horn to the car wiring the other needs to go from the back of the horn push to the inner metal on the steering wheel boss
Cheers dude :)
  • 7 months later...
iv got this problem too did you find out which wires go where ??
There should be only one wire coming from the ring contact inside the boss itself, this connects to one of the contacts on the horn push. The othe contact on the horn push needs to be connected to the body of the boss itself. Test it be touching the wire into the body of the boss. The horn push switch completes the circuit when pushed.
HTH
ok dude cheers ill try it today ill upload a picture if i get stuck sorry for bringing up a old thread
ok so i tried the above and it has not worked tried the wires every way round possible took some pictures there not good but hope someone can point me in the right direction
this is the boss with the wheel off there is a black wire
430496_10150649080704740_603124739_11201
this is the back of the horn on the wheel
401140_10150649083419740_603124739_11201
this is the yellow wire that was supplied with the boss kit
419585_10150649085299740_603124739_11201
as i said iv tried linking the wires up to both metal bits and tried earthing to the boss still nothing ..
Look at the back of the boss and the original wheel do they lok the same? Maybe the rings are in the wrong place (wrong boss) failing that have you tried connecting the black wire to where the yellow one connects to the boss?
