bonnet lifters
I've bought some bonnet struts from venom for my bonnet and they dont seem to budge when i try to compress them, and even when I'm sat on them the weight doesntmove them! also,m how do you fit them becasue the instructions dont make a blind bit of sence and the diagrams are shit!
  • Replies 9
  • Views 2k
Tailgate struts are exactly the same, don't worry about it.
you cant compress them you self, you need the leverage of the bonnet.
basically on passanger side you replace one of ther wing bolts (think its 3rd one from back) and one of the bonnet hing bolts with the ball bolts ( bolts witht balls on the end). then push lifter over the ball bolts ( make sur you take out the locking clip 1st)
drivers side is the sam accept you have to drill the hole for the bolt.
I didnt do this and i'm having now problem with bonnet lifters
hope this helps
Chris
Can you not use any wing bolt? or would it fudge it by doing that? I mean, why specificaly 3rd bolt from the back?
if you use a wing bolt to close to the back (near windscreen), its wont close as you'l run out of room, and any wing bolt to near the front (eg. lights) and it wont open
Motorways are easier than driving on normal roads :-)
or when u shut bonnet, you'll bend the bonnet or the strut! I came extremely close the other day!
Can you use the struts from your boot?
I did this on my mk3, i think its pretty obvious which bolt to take out.
Is the kit specifically for your model?
yes its made for a 6N, i was just wondering where the top bolt went. do they take bedding in?
  • 2 years later...
I just bought some JOM lifters and they have german instructions. So its the 3rd wing bolt from the back, and one of the bonet hinge bolts. I'm guessing its any of the hinge bolts???
Scared or bending something hahaha
