a question to all you 1.6 8valvers...
i've just had my gearbox changed by a local gearbox place near me
now before, whilst cruising on motorways at 70mph, the car used to sit in 5th gear at about 2500-3000rpm
now today after picking it up, i reached 70 in 5th gear but the car was at about 4500-5000rpm!
it also cruises happily in 5th at 30mph at around 2000rpm...
gear 1 2 3 and 4 feel really short aswell
so is there a possibility they've put maybe a 1.0 or 1.4 shorter ratio'd gearbox in?
what rpm does your car sit at when driving 70 in 5th?...
  • Replies 38
  • Views 3.9k
i have got bigger wheels but only do just under 4 k at 100 mph think u gota 1.0 -1.3 box , mines a 1.4 8v btw
I've just had a box fitted so I'll have fun checkin it out on the way to work I'll let u know the outcome
I need to sort out the linkage because I'm putting it in reverse for 1st at the moment and reverse is way over by the passenger window
100mph at 4k?? Do you put TNT in with your petrol? I have same engine and 100mph is Over 4k is it not??
Has it got other mods?
yeah i have and you are only on 13s I'm on 15s i have a greater roling radious
I never realized the rollin radius could add so much speed! Nice one! What else it got eninge wise?
I'm running 16's by the way..
It was never like this before either, only since I picked the car up yesterday
Sounds like they have changed the ratios in the box or put on a different box
i have just had mine replaced with the clutch got the box of a guy on here said it was a 1.6 box , but i swear accelerating off it seems faster, which the 1.4 box would do am i right??? but i still get the top end speed???
maybe it cause i was drivin a 1 litre around whilst the car was waitin to be done!!
I'm running 16" on my 6n 1.4 8v and at 70mph it sits at 3250rpm so i would say that your box is a 1.0l or maybe 1.3l GUGZ ???
Almost sounds like a valver box. But even then a valver is doing 80mph at 4000rpm.
this is ghey, going to take it back to the garage later an make them sort it out, re-conned gearbox my ass
i'm guessing an hour long motorway journey at 4500rpm isnt advised? :lol:
make sure you make the most of this temporary short ratio gearbox :ninja::lol:
Wouldn't do any harm really.
You should be able to sit at 65mph happy on or just under 3k revs, 2.5k is the best to save fuel ;)
sounds like you have my gearbox!
at 140 km/h it is at 4200 rpm..
my old 1.6 8v gear box was much lower in revs at that speed
i think you have a 16v gearbox on you are thingo
gugz I've got a 1.3 8v and at 80 mines at like 4500k aswell i think they may have put the wrong box in dude!
best way to tell is....
travel on motorway at 60mph, time yourself from 60 to 90. if its under 10 seconds (without changing from 5) chances are you have a 1.4 gearbox....i no this i had one. it gives you alot more tourqe so you will pull away from a vrs off the line.
Defo played with ratios or put in the wrong box, where you get it done guggz ???
Exchange gearbox???
They've clearly given you a shorter ratio box,and whilst it will improve your acceleration,your cruising mpg will plummet because your engine is digesting fuel at a faster rate whilst at the same speed.
They may have used a box from a 1.6 but various different boxes were fitted,and the only way to ensure the same ratios was to fit a box of the same code - something they've obviously not done.
if u increse you are roling radious u have to change the spedo conector to componsate , and running performance plugs and leads powerflow full system this makes no difference to what revs you are doing at 70 though just helps mpg and accselaration
sorry but...say whaat? :lol: i cant even get to 90 with this box, it tops out at about 75-80
Exchange gearbox???
yeh bro thats the one
yep mikey my fuels getting used up like a mo'fo even during short motorway journeys
have to say acceleration is improved through the rev range, but because i can only get to 60 in gear 4/5, the time used changing up 4-5 gears counteracts any gains in acceleration
called them up today an they're going to take the car back on monday to change it, this is going to be my third box from them now, luckily all covered under a 12month warranty
i had 15's on my old 1.6 8v polo and i couldnt reach 100 at 4krpm?...
sounds like they put in a 1.0 corsa c comfort gearbox LOL
what tires did u run ? aspect ratio ?
