Removing Side Strips
my friend does bodywork, he pulls out dents e.t.c.
we used adhesive removing spray first and then started to pull away the plastic strip.. however he stopped and studdenly said that theres paint flaking underneath and its not a good idea!!
i told him its only glue it will be alright... door should be fine underneath.... but then after arguing we agreed to put some glue on the strip and put it bak together
has any one else ever encountered a problem taking off their side strips?...
what should i do!!? :cry:
  • Views 1.5k
The glue does pull the paint off in some cases. I did with mine (lost a 50p size bit). Your choice, leave them on, on take them off and have the paint sorted.
I'm sure you cant just spray the bit where the bump strip was...
wouldnt it be noticeable... especially on lighter coloured cars!
1)Boil a kettle full of water
2)Pour water onto the strips
3)Using dental floss, carefully and slowly prise away the strips
4)Petrol on a rag, rub into the adhesive still on the car, then use an old credit card to 'scratch' it away (doesnt actually scratch your paint)
TIP: Don't pull the strip off, like i did at the final hurdle, i pulled a small bit of paint off that way, other than that, my method is perfect (Y)
thanks
that thread helped alot
Speno- ill try your method when the weather gets better and see how things go!
yeas sometimes no matter what u do it will always pull the paint off. but surely if you are mate workso on bodywork he can sort u out with a bit of spray paint!
