Is the damage worse than I thought?
My girlfriend had an accident with a Volvo a few weeks back involving the o/s wing and door taking a pretty good beating. I've now bought a new door, wheel arch, two wings and a wing mirror.
I was going to fit them this weekend, but I've just noticed something quite alarming, which may point towards the damage being more serious than I thought.
The panel gap between the n/s wing (which did not come into contact with anything) and the bonnet seems to get larger towards the front of the car to the point where I can actually see the bolts that hold it on without having to lift the bonnet! This is parallel with the wing that was hit, where the front of that wing sits just under the bonnet.
Also, the front grill sticks out a cm under the bonnet on the o/s but not on the n/s. One possibility would be that the bonnet was shifted in the accident, but it's parallel with the windscreen and if it was moved the panel gap between the bonnet and the n/s wing would be smaller rather than larger. These pictures suggest that the entire front of the car has been shifted about 0.5 to 1cm out of line with the rest of the car.
n/s panel gap
I thought just the wing was under the bonnet, but it may actually be the frame/chassis (whatever). If I try and put the new wing on and it sits under the bonnet rather than beside it, that will probably tell me whether the car's screwed or not.
How serious is this? Should I just buy another Polo and give up on this one? The tracking seems to be slightly out although it's no way near as bad as my last Polo.
  • Replies 12
  • Views 1.7k
dame thats not good mate
i've got a bonnet if you need one
When you put the new wing on you will just have to tweak the bonnet for cosmetic reasons.
I fixed this:
I think I may have been a bit over-worried. Fitted the new/old wing and it doesn't look too bad (apart from the fact that it needs painting! :lol: ).
I think in hindsight the bonnet was pushed back from the front o/s when it hit the volvo as it was actually stuck under the wing after the accident so this probably accounts for the panel gap the other side. I'll be fitting the new grill tomorrow and then I just need to fit the new door next weekend, but it needs putting together first as it's just a shell. Then get it all sprayed again, including the valence this time and we're back where we started.
New wing (now not sitting under the bonnet. :-D
Panel gap - just need to hang the bonnet right now
small gap at the bottom of the valence, but I had a problem here previously
Original parts - no panel gaps (+ cheeky alloy(s) shot) :-)
Car looks pretty straight to me
just gotta sort that door out!
Is there anything I can do about this bumper as it was brand new and it would be a shame to get rid of it just because of the corner? Obviously I'll have to bend the metal back, but is there anything I can do about the plastic? Heat it where it's split?
looking good mate
i've got a front bumper if you need it
Could always weld it, jack1 does things like that, lookin traders classified :thumbsup:
looking good mate
Did you spot your wing mirror in the photo? :-D Cheers for that mate!
looking good mate
yes i did it looks better on yours than it did on mine LoL
i'm starting to regret striping mine now but its too late now :-(
Unfortunately it was for the best. Looking at where you had removed the n/s wing, you had a serious rust problem!
Edited due to fat finger syndrome on the keyboard.
Edited by Giw
can i have a front/side on view of yer car please
am going bumper less and want to know what it looks like,just fitted turantulas aswell 8-)
Tarantulas FTW! I refitted the bumper earlier on today. Sorry. If you have a look on here I've seen plenty of bumperles mk2s.
You have to figure out how to attach the indicators or buy Landrover indicators so I'm led to believe and then you've got to fix the number plates.
If you're doing the back as well you need to figure out how to light your numberplate. As I said, there are plenty of people on here who have done it.
Good luck!
Also, looking at mine tonight, the bumpers screw into quite a chunky bit of the car, which obviously did its job and protected the valence when my Polo hit the Volvo. If you remove the bumper, you'll be worse off if you have an accident.
Also, the front on look is cool, but looking at mine this morning from the side isn't so great as the grill sits out further than the valance, which I think doesn't look great.
Edited by Giw
backs off,no number plate lights!!! :shock:
front comin off too but i have some ideas for corner bumpers 8-)
I'm intrigued. Where you gonna attach the corner bumpers as the corners have no structural integrity?
Post some pics when you're done! :-)
