tinting mk3 rear clusters red?
hey guys, i was wondering what looks better tinted, early or late spec mk3 clusters?
  • Views 1.5k
i would have thought the finish would be better on early spec lights, also wouldnt want to ruin a set of late specs.
use early ones. use a palm sander to remove the writing moulded into the plastic. do the whole indicator section though. you should be left with an opaque finish. this helps the tint spray to adhere and you will also find you dont need so much tint spray as the indicators wont be so amber in colour. an added benifit of this is that your idicators will still shine through orange, as the tint coat is so thin.
once the tint has dried you will notice the finish looks a bit matt. this is solved by clear laquering over the top, then polish them up with a good quality polish like meguires.
this is how i did mine and they havnt even faded!
Hey guys! How can you tell the difference between early and late spec rear lights? :paranoid:
early has orange plastic where the indicator is
late has grey plastic and i think the entire light cluster is slightly darker (tinted)
Cheers pal! When did the late ones come in then?
later L reg models had them
