AAU 1043 mk3 coupe engine sensors..
can anybody tell me what switches or senders go into the head on the upper right of this engine??
I'm fitting this second hand unit which is missing these senders. my car is a 91 and this unit is a 94.
the 2 senders are the one with the blue and yellow leads leading to them..
any help would be very much appreciated
thanks
mike.
  • Replies 8
  • Views 1.6k
Oil pressure switches for high & low pressure. Dont know the part numbers though. Maybe someone else can, & which goes in which hole.
cheers for the info dude, so does anyone know part numbers or have pics? I think the bit around the spade terminal is coloured so any sort of idea on colours?
i'll have a look at colours for you 2mora at work its raining at the minute so I'm not going out now, but if i recall they are just metal sensors...no colour will try and find part numbers aswell not going to take them out though.
Mine is a 93!
Mine is a 93!
very very very much appreciated thanks!!
:-D
Mine is a 93!
:-D
No probs mate thats what were here for!
Can you see with the air cleaner on i can't remember?
Mine is a 93!
:-D
Erm not so sure about that one matey.. me old engine is in bits :?
Mine is a 93!
:-D
No worries will have a look and try and get you a picture if not 2mora then definatly over the weekend sometime!
blue wire is low pressure and yellow high.
did your original engine only have the one with the blue wire?
