weight loss ~g40???
hi dubbers,
i am new to this site and was just interested to know the overall weight of my polo 6n2 (2000) gti?
i'm currently 90% complete on the build of my 6n (originally 1.4 16v) g40 but have had a change of heart, i'm thinking if i can reduce the weight of the gti then i'd transfer the g40 lump into the 6n2.
obviously i'd be removing the full 1.6 16v running gear, power steering, cable change linkage, aircon rad and climate control unit and abs set up.
i'll also remove the gti trim (and seat belts) for two lighter front seats with a stripped rear, also will be running old school rare bmw 13" rims which means rear disc set up will have to go and fronts down sized to vented 6n 1.4 8v items.
possibly fit non gti front bumper to lose the washer jets to save a little more weight?
any ideas on possible weight loss? thanks.
  • Replies 45
  • Views 10.1k
if your a fat git then hit the gym
sound deadning
poly windows
get all the sealant off the arches/underside
fibre glass pannels
get the hole saw out
alloy fuel cell
depends how many monies you have
To me putting a G40 in a mk5 is just complete false economy. G40s only really have an upper hand because they are a relatively powerful engine in a small light shell. You go put it into a heavy shell and its going to be wank. For the money and effort its gonna cost to you to shed those pounds you'd be better off keeping all your luxuries and tuning the GTI.
Cut the spare wheel well out and weld a flat plate in .
Iff your going for more power surely you will still need the disk's on the back ?
As heatagram says .. Why not Turbo the Gti lump ?
Wouldnt advise removing any safety features iff you want more speed mate .
Yeah, if I was going for more power I'd want to a least keep the standard brakes. Not make them smaller.
firstly i didn't ask for abuse, just some helpful info! i joined this morning and already see you are a nice bunch!!!
the 16v lump is shite, any power is after 4k, i don't like turbo's and it's up to me what i do with my car!
as for safety features abs isn't worth the bulb in the dash and power steering is really for girls!
gti brakes are crap even though they have discs all round, the 6n 16v with rear drums and no abs worked far better!
i want to do something different, is that soooo bad!? i've had 3 g40's i like the engine but the shell's aren't good with the power even with strut bars, roll bar blocks, weld in stability bars, solid mounts and polybushes so have opted for a car with proper wishbones to put my g40 power down! if you don't like it do 1, i didn't ask you to!!
thanks for all your 'help'!
What the hell you on about abuse.
This is a discussion forum and people will give you there opinion. My PERSONAL opinion is that there are better ways to get a mk5 go fast than with a G40. Thats all I was saying. Brakes are going to help you stop, which is essential. Its one area I would never consider downgrading, especially if I was intending to gain more power from the car. If anything I'd be wanting to put bigger brakes on.
As you say its your car and your wallet. Do what the hell you want. Next time I won't offer up any suggestions that might get you more bang for you buck :roll:
If it was power then wouldn't i'd just 1.8t it? i'm fitting 13" alloys so big brakes are clearly not an option!
I asked for info on weight not if you think my project is 'wank', thanks for your input, be sure not to respond in future!!
Don't worry, I won't :)
So upgrade an engine and downgrade the brakes, surely thats gonna result in an accident!
Nobody said it was wank mate .
Good luck with the project .
Never heard of anyone G40 a Mk5 before so its certainly different.
I look forward to seeing how it turns out :)
Bonjour - I think the poster is a mate of mine from back home...
Mate - i'd sell the GTI as is and get some cash back to get the 6N up and running - it'd be easier as you are already done - dont lose faith in that as it could be a good little project and see a nice return when finished.
Kam - this guy is a c-razy good driver - hates ANY electronics - and would much rather have a nice small light Mk1 Golf with the 40 in it...lol :lol:
Theres too many "options" when considering a conversion - because it will be custom to some degree either way...
If you want to pull apart the 6n2 and swop it over - then do it - it'd be unique, one off, custom etc - but like you mention the weight is a problem.
I'd be tuning the G40 a bit more to run in the 6n2 if it were me - but then again i couldn't do anything like this on my own either!
Tough decision - especially when you have the potential sat right in front of you...
If you want to do a G40 conversion for handling drop it in a mk1 golf. I think its the 1.3 where the engine mounts are the same.
Power to weight - Get your PY lump to 150bhp. As far as I know a GTi weight just over a tonne. 150bhp/tonne is not exactly worth the hassle. A mildy tuned GT can get 130bhp/tonne.
Although from your replies about brakes etc I don't think performance is top of your list. If you want to do something for the sake of being unique then there are much more interesting engines to put in. TSi, TDi, Convert the GTi to run on ethanol.
This guy already converted one for another guy back home - in all honesty i think we would all prefer to have that but for doing something different the 6n2 would definately be that bit different...
I'VE ALREADY DONE THAT A COUPLE OF YEARS AGO (THE MK1 GOLF G40) (1362) YOU STILL NEED TO FABRICATE A DRIVERS SIDE MOUNT, GEARBOX MOUNT AND ADAPT THE REAR !!
I LIKE THE POLO 4/5 AND THE G40 ENGINE, A FEW PEOPLE HAVE PUT THE G40 LUMP IN THE 6N WHICH IS WHAT I HAVE DONE, BUT THE ONLY STRUCTURAL DIFFERENCE ARE THE REAR QUARTERS REALLY. EVERYTHING ELSE IS PRETTY MUCH THE SAME AND INTERCHANGEABLE.
THE MAIN REASON I'M PONDERING THE 6N2 IS TO GET MY 6N UP TO SPEC INC PAINT JOB ENDS UP IN THE 3.5K REGION AND AS MY GTI DIDN'T SELL FOR 3K AND IS PARTICULARLY CLEAN I THOUGHT WHY MESS ABOUT SPENDING 3.5K ON MY 98 6N TO END UP WITH SOMETHING THAT HAS ALREADY BEEN DONE? WHEN I CAN SPEND JUST OVER 1K TO PUT IT INTO THE GTI AND END UP WITH A BETTER, NEWER CAR WHICH IS ESSENTIALLY THE SAME AS THE 6N WITH APPARENTLY 100KG BETWEEN THEM?
ALSO I COULD MAKE MONEY BACK ON SPLITTING THE 6N 16V AND FLOGGING THE GTI PARTS OFF SO IT'D ACTUALLY BE CHEAPER TO DO THE 6N2 GTI AND SAVE ALOT OF TIME AND WORK, RECKON I COULD DO IT NICELY IN A WEEK!
SO BACK TO MY ORIGINAL QUERY, DOES ANYONE ACTUALLY KNOW THE DIFFERENCE IN WEIGHT BETWEEN A 6N 1.4 16V AND A 6N2 1.6 16V GTI?
AND YES DAVE YOU KNOW I'D RATHER HAVE HAD MY SMALL REAR LIGHT MK1 G40'D BUT TIHS HAPPENS!
I'M NOT DOING THIS FOR SPEED OR JUST BECAUSE, I LIKE THE POLO 6N SHAPE AND THE SIMPLICITY OF THE G40 ENGINE AND SET UP, I'M NOT AN IDIOT AND WOULDN'T DOWN GRADE MY BRAKES IF I WERE PLANNING TO RACE OR WASN'T CONFIDENT OF ACHIEVING STOPPING POWER NEAR EQUAL TO THAT OF THE GTI WHICH ARE FRANKLY POOR ALL THINGS CONSIDERED! UNTIL IT IS UP AND RUNNING I COULDN'T COMMENT AS TO IF I'D NEED SOME 4 POT WILWOOD'S BUT I WILL 100% BE RUNNING MY 13" BBS SO THE DOWN SIZE IS A MUST!
http://www.wisebuyers.co.uk/motoring/car-s...99%29/VW001697/
http://www.wisebuyers.co.uk/motoring/car-s...02%29/VW002733/
Unladen weight specified towards the bottom - 'Key Dimensions'.
6n - 1025
6n2 GTI - 1084
Diff - 59
SPOT ON, THANK YOU! THERE ARE SOME HELPFUL PEOPLE ON HERE AFTER ALL.
LOOKS LIKE THATS THE CLINCHER THEN, I SHOULD BE ABLE TO SHED 60K FAIRLY EASILY, HOPEFULLY EVEN GET IT DOWN TO AN EVEN 1000KG WITHOUT TOO MUCH HASSLE!
Amen to that - that car was pure filth - absolutely nuts!
Memoirs (this is the 1362 small light mk1 golf G40:
This is my conversion after crashing my G shell - Olly makes this easy as A:
B:
C:
LOL :lol:
Then onto something else:
From the sounds of things - losing 60KG's is easy enough - PAS / ABS will cover that easily 8-)
Gota see this when done...
:shock:
I THINK A G40 MK5 WOULD BE PRETTY COOL, BUT AS KAM SAID THE REASON THE G40 IS SO QUICK IS BECAUSE IT WEIGHS NOTHING. MAYBE A 150 BHP AVY IN A G40 WOULD BE A NICE BALANCE :) OH YEAH AND POLO GTI BRAKES ARE A JOKE, ANY OTHER POLO WITH DRUMS HAS MORE BRAKING POWER
whoops caps!
:? If thats your experience, there is something severely wrong with them
Erm, doubtful
I reckon losing those two wont even save you ten
my 6n g40 goes really well was really suprised after doing the conversion and far better on handling than a mk3.It sounds as if your in the same boat as me as mine needs paint now but tbh if you fancy putting it in the gti go for it and as youve said will probably end up better of after doing so I'm sure theres plenty of ways to lose weight
interior and loosing all the pas etc you wont be far off a 6n if not lighter GO FOR IT
luke
Erm, doubtful
Jez is known as the local "know it all" guy - ignore his rambles...
I would say he is one of the "special" people around here :lol:
Did you not once use some 2 by 4 to fix you are battery in Jez?
There is definately something wrong with my cars brakes. Bleeding the system, new rear pads/discs, upgraded front pads/discs - exactly the same :(
Erm, doubtful
:lol:
Your such a fucking specialist its unreal
Do you even know what your talking about?
Ignore my "rambles" as you put it? well as they are based on what I know, I would wager its a large amount more than that of your knowledge no? your posts highlight your complete lack of knowledge in the subject you preach, easily lose 60kgs from the PAS and the ABS? are you on fucking speed? or have you just run out of your prescription Ritalin? where are you getting all this information from? or does it come from the same place as 90% of your posts down in the deep brown of your arsehole?
and I have no idea what the fuck you are on about with saying "did I not once use some 2 by 4 to fix my battery in" and I expect you have no fucking idea either, (as usual) what you are even talking about
:lol: I genuinely enjoy reading your posts Dave, as they never fail to make me feel better about myself, at your expense
