Exhaust fell off!
Driving along the M3 on the way to work yesterday. Oh look, why's she flashing her lights at me? As it happened, we were just approaching Fleet motorway services so I pulled over and got out, expecting to have a flat tyre or even for there to be lots of smoke coming from the exhaust (possible head gasket failure?).
The bloody exhaust was hanging off at the back and scraping along the ground!
Scraped clean!
After trying and failing to get through to my breakdown people (Auto Aid don't seem to answer the phone before 9am) I tried to figure out a way to fix it myself. There was nothing in the car I could use, and nothing useful in the shop. Luckily there were a couple of guys having breakfast in the back of their van who gave me a handful of zip ties which I used to make a temporary hanger for the backbox. It looked like something, a clip maybe, was missing but having not had a look at it before I didn't know what had gone.
Anyway, the zip ties got me back to SJB Autotech in Basingstoke (where the GT had been serviced the day before) where Jim told me the rubbers must have perished and fallen off. He also mentioned that they had had some trouble getting the car on the lift on monday because it is quite low (only -40mm though), and they might have knocked the exhaust. So he fitted some new rubbers free of charge and I was on my way.
Zip ties, though, is there anything they can't do? I'm going to make sure i have a supply of them in the boot from now on.
The only thing I'm worried about now is will it happen again? Have a look at this:
That right-hand hook looks like it's going to snap soon. What can I do about this (preferably something cheap and easy that I can do myself)?
Edited by steveeeee
  • Replies 23
  • Views 3.3k
my mounts as like many others bent so much the rubbers fell off on a contry road, managed to bend them back and renforce it with wire!
thats definalty going to fall off again you need to get that right hands side hanger bent back up towards the bodywork but i suspect it will need renforcing
Stick a bit of dowel between the flimsy wankers. Or drill them and bolt some studding through them?
weld it, or make some new ones up and bolt it
My mechanic already bent it up yesterday, I think it's gone soft through rust. Shame the upper hooks are so flimsy, cos the hooks on the backbox look pretty tough.
I'm curious to see exactly what you did, do you have a pic?
That's a nice idea, I'll see if I can sort something super-quick pikey style before I head home tonight :thumbsup::thumbsup:
I made a new one and bolted it onto the car. Worked fine for me and I had uber hard suspension that broke everything!
Ahh fucking hate the polos exhaust setup
your problem is the same as mine. The right hand one should be further right >
Bend it slowly to the right place and then get some weld on it. Thats what i NEED to do! Currently using washing line. lol
But the exhaust falling off isnt always as novelty as it sounds, a few weeks ago mine came off whilst going round a corner at 30mph, the exhaust hit the floor, sheered the clamp and the exhaust did a 180 right under my back wheel. Could of easily caused me to crash if it was wet. So you really need to sort it mate.
Not keen on anything that needs welding as I can't do it myself, and I'm too tight fisted to pay someone else to do it! It got me home tonight with a few jumbo zip ties on, and I've got a stash of them in the boot now. I've got a few possibilities on how to fix this permanently but the pressure's off for the moment and I'll have a good look and a think before I go ahead with something.
Cheers for all the advice and suggestions! I'll update later when it's sorted properly.
same thing happened to mine, got my brother to weld it up and 2 months later it's still all fine!
try abit of flat bent steel and put a couple of self tapping screws through the steel into the back of the hanger then up into the base of the car then slap some araldite on it to tidy it up and make it uber strong
I got mine welded back up, haven't had any problems since. Bad design tho
I ended up taking the rubbers off and tieing it up with some jumbo zip ties. Been running on those since mid-May and no problems so far!
my zip ties snapped when i used em to hold my exhaust up
bike chains on now haha
there a crap design, how the hell did you not hear it!!!
Thats exactly what I thought Steve, how can you not hear your exhaust scraping along the ground? You fucking deaf or what?? :shock:
I think I may have had some tunes on :D:ninja:
Since getting a job that's walking distance from home I only take the GT out once or twice a week for short runs around town, so it's less of an issue now. I'll sort it out properly at some point.
i've used various items in the past, removed shoe laces, zip ties, toe strap from a bicycle pedal, a rubber that was too small and caused the other rubber to break, fencing wire, a bicycle lock. at the moment there is 2 brand new rubber, i'll give them another month or 2.
There was a thread somewhere in polo chat about some chain link rubbers... dunno if that's any good??
Get searching on there :]
Happened to me once,wont happen again..
Is that a piper backbox Mikey?
No,its a MK2 german spec GT item,with a bit of stainless pipe terribly welded on (i only had mild wire and no gas at the time - rice krispies). The rod was 10mm zinc plated mild steel.
I have a new system in the post,which will be an improved design.
That same thing happened to us,rubbers had perrished over the years,we just put some new rubbers on and that happened-early this year? haven't fell off yet.
(you watch I will say this and the bloody thing will fall off tomorrow! lol)
tie wraps/zip ties whatever you want to call em. They work wonders if you use ones that are strong enough! and they can hold it up real high if you're running a big drop.
Mine has fallen off 4 times in 2 days, mounts on the car are fubared :@
