Bucket seats and matching Coupe S rear bench
They pretty mint, the white stuff is just the remains of a sticky label which I've had off.
Will go straight in your Mk2/3 hatch :)
£120 ono plus your old front seats.
Edited by AdamP
  • Replies 21
  • Views 771
will harneseses fit these?
I would have thought so :)
Adam
were abouts in berks are you? might come take a peek if thats ok, as by the looks of it the hole in the back is to high to run harnesses through.
cheers
Edited by xcore
That's fine for you to come and have a look! I'll even nab one of the harnesses from the 205 for you to try if you want.
I'm just off J14 of the M4, can PM you a postcode if you want.
Adam
I'm pretty sure the hole isn't too high. This picture shows the seat next to a standard one (which I unfortunately dumped!):
Considering the bucket seats are sat lower as well.
Adam
Postcode please?
Btw. The rear seats will go straight into my Mk3 right?
You have PM.
And I'm pretty sure they will! Might want to check with someone who's tried first though.
I'm around on saturday with all the tools out so if anyone wants them it would be ideal!
'ONO'
bump just in case!
does it matter what cndition the replacement seats are in as i ahve 2 coupe s ones but the drivers has a hole in the bolster and i already have that rear bench would you sell me jusr the fronts??
then you would still have a matching set of seats??
max
Edited by polo.6n.max
max
Not really that bothered on the condition as long as they're useable tbh. Could do you just the fronts for £90 if you collected this weekend!
Adam
Edited by AdamP
these height adjustable? just wondering cos I'm a short fucker
ok well i have a mk2 coupe s so i wouldent need the rear bench and my front seats will match your bench.
the drivers has a hole on the bolster but i cable tied it together lmao stop it gettin worse.
do they adjust in any way??
max
They can be spaced up and down with washers and longer bolts, and they slide forwards and backwards on the standard runners.
Still here!
Around on Sunday for a bit if anyone wants them!
do these come with sub frames and oo yeea where abouts are you located
Yep, they're all ready to fit with subframes.
Bare in mind that they don't fold forward... but it's easy enough to climb between the seats.
I'm located near Newbury, Berks.
Still here.
Edited by AdamP
