Tutorial: 9n to 9n3 rear light conversion
okay, credit to member KJS for figuring out the passengers side conversion
there are two types of 9n light, left side reverse or twin reverse lights
Tutorial for left side single reverse lights:
(tutorial by KJS)
only adjustments that need to be done is the passenger side tail lights....the driver side is the same so you dont need to change anything...its just a direct fit in....
Now, for the passenger side you will need alot of patients....Here is some info:
numbers 1 to 6 represent pin numbers marked on the side of the clips
Passenger Side-------------
9N WIRING
1 Brown =earth
2 Black white = indicator
3 Black/Red = brake
4 Black/blue = reverse
5 Blank
6 Grey/black = lights
9N3 WIRING
1 Empty
2 Reverse
3 Indicator
4 Ground
5 Brake
6 Lights
for twin reverse lights to single reverse light conversion:
(tutorial bydanielpasieka)
wire the passengers side as above, then wire the drivers side as so:
9N WIRING
1 Brown
2 Blue/Black
3 Black/Red
4 Green/Black
5 Grey/White
6 Grey/Red
9N3 WIRING
1 Grey/Red
2 Black/Red
3 Brown
4 Green/Black
5 Grey/White
6 Blue/Black (or leave empty, wire isn't connected at this end anyway)
  • 9 years later...
  • Views 18.6k
Hi, looking to do this but I don’t understand what is meant by single and double reversing lights and which one mine is? (9n1 2004)  also the post says about nothing needs to be done about drivers side but I already put both 9n3 tail lights in and neither was working but could this just be because the right one was faulty?
Thanks,
Lauren
