polo faults
hello its me the new lad, am going to look at a 1992 coupe 1.3 cl on thursday and a was wantin to no is there any thing a should be lookin out for i.e rust and what hav you any help would be great
thanks anth
Edited by the-mint-with-the-hole
  • Views 1.3k
any 1?
Look under the battery, the battery tray is the most popular place to rust.
The first thing to check for on any Polo is rust.
Under the battery they often rust through. Check by looking up under the dashboard directly below the battery. Its not easy to do a proper repair here. Use a torch to help you look, and obviously check from above looking down beside the battery.
The fuel tank filler neck rusts and often leaks, particularly when the tank is over half full. The only real solution is a new tank, these are around £60.
The tailgate is prone to rusting around the bottom of the bonded in rear screen. Removing/replacing the screen to fix the rust isn't easy or cheap.
Check the sills below the doors and in particular their ends inside the rear wheel arches. Holes in the ends of the sills aren't easy to fix properly.
Doors and front wings can rust too, but they are easy enough to replace if the rest of the car is worth it, ie; very cheap and other wise good in condition.
Mechanically they're as tough as old boots. However, head gasket failure is quite common. Check for oil in the expansion bottle or thick white creamy deposits ( :oops: ) in the oil filler cap. Often they just leak oil externally on the far left hand side of the block/head joint, just above the alternator. For this reason the alternator is often covered in thick black gunge. It's not expensive or difficult to replace the head gasket if you're handy with a set of spanners.
Depending on what you're used to driving, you may find the brakes a bit poor. In good order they are more than adequate though, they just don't have the bite that a more modern car might have. If the pedal is long and spongy in feel it's more than likely the rear brakes are out of adjustment and/or worn. Check the handbrake, if it has loads of travel it'll pretty much confirm it. New parts are dirt cheap though.
Suspension wise, listen out for noisy wheel bearings. The back ones are prone to wearing out, easy and cheap to replace though. If you hear knocking at the front when you go over bumps its more than likely the strut top mounts are knackered. Cheap to buy, but not always so easy to replace.
Hope this helps,
Richard.
thanks for the tips mate cant wait to go look/buy it on thursday al keeps yous posted
Breadman, what good advice, I would also check a lot under the bonnet for rust anywhere! check brake pipes if you can because they seem to rust like nobody's business.
Its all been pretty well covered,but id focus the attention on,and under,the rear axle.
A battery tray and a wheel bearing easily sortable compared to a rusted chassis leg - have a good prod all the way around the rear arches and in the box sections at both ends of the rear arches. If its all solid,you've got a generally solid shell,and anything to worry about at MOT time is gonna be easy fix.
