Urgent: Bodged Job From Nationwide Autocentre
*MK 4 1.4 CL 96 plate*
To cut the story short. I went in to have my exhaust replaced yesterday. Somehow they managed to snap off a connector from the thermostat housing?? I was told to leave it over night as they needed to order a replacement part and to collect in the morning. This morning I went to collect it. After getting it home I checked under the bonnet to find out the part appeared to have been SUPER GLUED together. I phoned them asking what was going on? apparently the van didn't deliver the part, and the only option they had was to superglue in the time scale i had given them?? They didn't tell me this at the time the slimy bastards!
On to my point, would you consider this safe? Tomorrow I'll be driving 360 miles and I'm a bit worried in case this part fails and the engine seizes up?
(the part with the new jubilee clip is where it snapped off)
Is this part called the thermostat housing? Is it easy to replace, I'm thinking of getting the part myself then charging it to them. would gsf have it?
Edited by dn852k4
  • Replies 11
  • Views 2.2k
yes thats the thermostat housing, think gsf do em, dont do 360 miles in it tho as you may end up on a recovery wagon, they shouldnt have let you have the car back imo
i'd kick off... BIG! you want a genuine VAG part on there for their fuck up!
it should hold, but then again, the pressure is pretty big in there, your engine wont seize, but could go up is a cloud of steam if it lets go... make sure you are not prodding it etc when the engine is hot, the temp of the water can get SERIOUSLY hot and can cause some damage to you, never mind the car.... SHOCKING WORK!! complain like fook! even more so cos they never said anything to you... cowboys...
Edited by Rick_GEEEE
Yeah, get it replaced if doing that milage i'd say.
The VAG item for a 1.6 is about £75, don't bother with the GSF; they're much worse quality
Just phoned up and told the manager i want it sorting today. To be fair he did say he'll make sure the part is there within the hour.
I think I'm owed a free service for this! but then again, do I want them neanderthals touching my car again?
I can't belive they let me drive off without telling me they hadn't actually changed the part - I would have waited if it meant the repair was done properly.
get the new part and never go back
tell all your workmates/friends /forums
might even be worth a mention of trading standards ..id ask for a genuine bit and go home and diy fit it
Oh don't worry I will. My dad used to get his car serviced there, doubt he'll be using them again!
yeah i mean whatever they offer you in terms of free services you cant trust em
theres no way that superglued pipe would last 5mins , its madness they tried to blag you with it
tell the boss youve took plenty pics and are considering what to do about it
Do you reckon I could push for a full refund on the exhuast?
worth a try mate..or a big chunk of money off at least
try on honestjohn.co.uk forum , theres some legal peeps that might be able to offer good advice
do as said above. make sure they are aware you know the dangers of it. and that you are considering what action to take. and that simply fitting the correct part is not good enough. dont let him get away with just a smile. remember its lucky you knew what your looking for . they were hoping you wouldnt notice!! :x
i agree with retrowagon1234, ask them what would of happened if you didnt check and did your 360 mile journey and it failed....
cowboys. At the very least it will make you feel better blowing some steam off at them! at worst, you learn a lesson and go elsewhere from now on. I had an experience with kwik fit, complaining didnt get me anywhere but at least i shop elsewhere now.
