What Splitter
i have had a search and found that laguna splitters, ibiza splitters and the obvious mk5 gti splitters fit but i need to know if there is any other splitter that will fit straight on without having to be cut or self tapped on. For example will the ibiza splitter bolt straight onto a 16v bumper through the same holes and be the right length. also what models am i looking for?? is it the mk2 ibiza (what years are they)
just about to go down the scrappy so thought i may pick one up if they have one. i definately dont want the 6n2 gti one.
thanks
chris
  • Replies 10
  • Views 1.8k
i take it there is no direct fit then. shame i thought there may have been.
nope.. ibiza mk2 is bigger bumpered than the 6n..guessin the laguna is 2. 6n2 is right size but different clips. venom do splitters for the 6n or its modding something to fit.
hope this helps..
david.
Edited by riskie
hope this helps..
david.
so there is nothing with same clips :(
hope this helps..
david.
not a hope in hells chance I'm affraid. even the 6n2 gti splitter has to have the lugs cut off t fit I'm affraid.
david.
isit true the mk5 gti splitter is the right length for the polo 16v bumper?? just a matter of taking my standard off and self tapping the gti one on??
yep. got too remove afew of the plastic clips on the rear but right length n shape. will make sense when u offer it up.
david.
have you got one on yours then mate?? also how much better do they look in your opinion
thanks
chris
they look alot meaner/aggressive than the standard 16v splitters....you cant go wrong really....go for the gti splitter....
thanks
chris
nope.. wouldnt fit my 6k.. too small. had one on my old 6n n looks spot on imo. :nod:
david.
Are the 16V splitters the same as normal bumper ones-say CL bumper splitters? Just that I'm probably changing my bumpers from normal CL to 16V and need to know whether I need another one or not?
