Locatting Rust On Mark 2's
Any Mark 2 is going to be at least knocking on for 20 years old now, so all but the very best will have some rust, but have generally fared better than other cars of the era as VW rustproofed most of them well. Check any car over well for rust, but particularly the following:
Colour is a big factor: Light colours, particularly silver are more prone as they have thinner paint than darker colours such as black, metallics, and never rust navy (so called because the paint on mk2's this colours is about 9 inches thick unibrow.gif).
The main reason for rust on cars that have it is the sill and arch kit getting moisture stuck behind it. It'll show when it's getting bad by creeping out into the visible bits, but before it gets that bad, it's worth taking the kit off and having a look. There is an article on removing the kit here, although it is for a mk3, the principle is the same.
Round the windows, particularly the rear quarters and windscreen can be bad, as water tends to sit here. With the window removed, any rust will be wrose than it looked with the window in. Don't let your scuttle start rusting out from this, as it is a mare to sort out. Likewise, look round the wiper arms.
Battery trays don't tend to be bad on mk2's, but have the battery out and take a look anyway, just in case a battery's leaked, or the drain hole's become blocked. Anything worse than a small patch in this area is a tricky job.
Tailgates on squarebacks and coupe's can end up rusting from the inside, this is normally because of the rear screenwash leaking.
Like any car, they're affectted by stone chip damage, this is unsightly, but unlikely to get bad unless left unchecked for long periods.
A big concern is the fuel filler neck, as mud can get stuck here for long periods of time and rust through the neck. Check the back of the sill round here well as it suffers at the same time.
Age of car is also a factor, the early ones were built and rustproofed better, though being older, these won't neccessarily have weathered better.
  • Views 6.2k
If anyone has any comments, or can add pics to illustrate points, this would be of use.
dunno how common on other cars , but my front jacking points were pretty ropey after a scrape down despite looking tidy before i poked at em
obviously all the salt spray gets in this area really well
a good jet wash underneath as often as possible during the winter will help no end
Some pics of a mk2 with rust spots as requested :-)
This is mine prior to respray and lowering about 2 years ago.
I am pleased to say that it is still going and despite being off the road for ten months i just got it MOT'd today with no problems :-D
http://us.f13.yahoofs.com/bc/47c88ccd_1792...Cao0kJBRDO4z9ti
http://us.f13.yahoofs.com/bc/47c88ccd_1792...Cao0kJBrSciuFZQ
http://us.f13.yahoofs.com/bc/47c88ccd_1792...Cao0kJBmIoWGUAc
http://us.f13.yahoofs.com/bc/47c88ccd_1792...Cao0kJBwc6WVNW6
http://us.f13.yahoofs.com/bc/47c88ccd_1792...Cao0kJBPhAtr18n
Hope these give the illustration you wanted!!!
  • 6 months later...
My '88 had a few problems..
..tip of the iceberg,it was in all the rear box sections,wasn't worth using the shell for the work involved.
Even my '85 needed work,but was far more solid.
