Push Button Start For £8 (guide)
My starter switch broke so i made this push button start up until i get it fixed it was piss easy and i did it for £8 though id share how i did it... don't no if anyone really cares but some people like them and its good in case your switch goes and you need the car asap.
You need a switch, some wire, a relay and a few connectors
tools you need some wire cutters, pliers and some electrical tape
All the stuff needed can be bought from maplin's for £8 the relay you need is where the switches are its on the same rack just find one with the same numbers as the one in the diagram its black with a silver fixing plate coming off it should be about 2-3 quid i forget the wires is 15 amp wire and the switch is one of loads they do lots of different ones in metal with lights and all sorts.
Basically just wire it up like this diagram says..make the wires as long as you need them for where ever you feel like putting your switch just hide the relay where ever.
You can still start the car like normal with the key if you like or just turn the ignition on to position 2 and push the button.. Rally stylee
*I don't have a picture of the ignition and starter wires yet il take one tomorrow they will be 1.4 8v 6N wires*
Click for a bigger picture.
It's a dead easy mod and can look pretty cool i guess with a nice shiny button mines out the way though in the little glove box under the steering wheel.
Edited by EthanMk4
  • Views 2.6k
WICKED....
wheres your car so i can steal it with ease... :doubt:
lol
At first i thought this was pretty much a guide to hot-wiring a 6N, but technically as you still need the keys present for the immobiliser, its not.
That is all.
:lol:
LOL True, i wish i would read all the Thread, but good job boyo!
It won't start a all without the key in because of the immobilizer this kits done exactly the same as all the ones on ebay and in the shops but costs you less than half the price I've seen push button starts in 100s of cars at shows and stuff.
Edited by EthanMk4
