Mk5 Golf Gti Tfsi Full Conversion
Sat in my garage is a complete TFSi setup from a mk 5 golf GTI.
Full list includes
complete TFSi engine including turbo and exhaust system.
6 speed gearbox with LSD
Gear selector housing and cables to/from gearbox
Both Drive Shafts
COMPLETE Wiring loom and I mean 100% complete.
Fuel tank complete with pumps.
Steering column with igntion barrel
Fusebox
ECU including the Ignition key
Clocks.
This has been painstakingly removed(especially the vehicle loom even cutting out the bulk head to prevent any cuts in the loom) to allow a smooth conversion. Having the standard management ECU clocks keys Fuseboard etc means you will not have to worry about aftermarket ECU's/ immobiliser defeats and overcoming the high pressure fuelling. IT is all there.
I'm currently looking at buying an RS4 as my new toy so the conversion is now surplus to my requirements.
It is all sat in my trailer, dry stored!!!!!!!
£1995
can deliver local to Rugby-midlands area.
Ben You can PM me on here or contact me on my mobile 07869293276
__________________
may the force be with you
  • Views 605
would u know if this is a straight forward conversion into a 6n2, and what is the max bhp i could achieve with this engine.thanx
not straight forward ull need custom mounts etc drive shafts same as u would need for a 1.8t conversion
I'm not sure how u could run it on the tfsi fueling system either
Hi,
Very interested in this!
Could i have a few pictures of the engine etc. I take its very similar as doing a 1.8T conversion?? This would be going in a Mk2 Golf..
Cheers, Randall
