Fuel tank bits you can bin?
my hecks slowly getting back together but I'm doing the fuel system at the moment......
i have already binned the charcoal canister etc but I'm looking to get more in the bin and as I'm doing my tank i thought it would be a good time to review it.
the standard system looks like the first photo below
in photo 2 i have binned all the bits in the red circle marked 1 but i want to bin everything in 2 also.
so it ends up looking like photo 3
only bit I'm worried about it the gravity valve (no14) as i presume its just a vent but do i need to keep it or can it be binned? as i recon it would vent the fumes anyway or does ti have a more serious function like and air lock?
Reason for asking is VW do 2 versions of the rubber filler neck cover (no 4) one that has the holder for the valve and a smooth one with no valve holder and i would prefer the smoooooth one but thought i would ask?
Factory1:
Bits to be binned 2:
What I'm hoping to do 3 smoooth simple and less clutter:
Help!
Edited by genesisGT
  • Views 1.4k
richard the valve is there so if you put the car on its roof the fule dose not escape out the tank throw the vent pipe..
do not take it out.. :badgrin:
You've basically simplified it down to the late 80's mk2 system but that part two you propose to remove on mine is just a u-bend on it's own (number 14).
I think the most important thing with these tanks is protecting the tank with the right product like stone chip and/or underseal. Especially the filler neck which I reckon has been one of the main reasons for the average joe to scrap the whole car. I've just completely stripped a 86 square which I reckon has had a new tank going by how fresh the metal is on the unexposed side. It has had no protection whatsoever so the filler neck is a rusty mess. POR15 might save it.
Finally a wee question, does it matter what way the float is facing on the sender or is that A shape on the cap indicate the way it should point like forward on the car? My fuel gauge seems to fluctuate, might be because of this?
Here's a tool I made to take off/re-fit sender:-
ah well better leave it then :lol: , will just keep the bit that loops into the wing then vent the valve to thin air rather than the canister pipe etc.
