DIY guide to stop bootlid liner rattling
If like me the black plastic trim inside the boot liner rattles like mad when in traffic or staionary and it annoys you heres a solution! here goes....
Take off the trim by unscrewing the screw in the handle then pulling the trim out window edge first as to not break the clips at the bottom
Get another plastic trim and took out the sound deadening felt stuff and stuck it to the one i took off my car (i used double sided sticky tape )
Then i put the cover back on the car, but it still rattled (not as much but still annoying)
So Then i had a brain wave i had some red lupo gti grill piping so i stuck it in the gap between the bottom of the bootlid and the plastic trim it worked an absolute treat no rattling at all and doesnt look bad either,
  • Views 1.5k
left hand side
right hand side
So now you notice that the pipping is too short, but you can get this stuff from various places (i know you can but i dont know where so please let me know where) cut to length, or if you have a couple of these plastic trims layin around there is black pipping in the trim that sits against the window in the boot and its also removable so you can take them out n make it fit!! Hope this helps!!!
