6N Mk4 Polo buying guide or common problems?
Is there the above around for the 6n as i have used the one on here for the mk3 polo, and found it very helpful :thumbsup:
Or can anyone give me some common faults to look out for on this model?
I'm sure this would prove to be a great help for others aswell.
Thanks in advance for any reply. :-)
  • Views 4.8k
look at wishbone bushes , brake lines and check underneath the sills and rear arches.
This gets asked all the time, there are lots of 'buying guide' topics on here but I don't think there's anything pinned. There should be though..
Off the top of my head these are the more common things 6N's apparently suffer from. This is based on my [excessive :oops: ] time on here, the only problem here I've had is the cutting out when pulling upto a stop (throttle housing)
-Gearbox problems are common
-Rust
-The engine sometimes cuts out when pulling upto a stop (when dipping the clutch) - a problem usually solved by cleaning the throttle housing out.
-Electric window motors stop working
Other than checking those things just make sure the cambelt (aka toothed belt) has been replaced sometime in the last few years.
Those are definately the more common things, I'm sure other people will be able to add more though.
Cambelt, door locks, power steering if it has it, leccy windows, oil changes and arch rust are the things you should be looking for, make sure they all work if the car has it, as they are common to failing. Look for rust and make sure it idles nicely.
