6N FOGLIGHT WIRING KIT
OK guy i have made two of these today and tested them and they work perfectly, The kit comprises of:
1x OEM style foglight wiring loom
1x Single wire that goes from fuse box to two stage switch (switch not included)
1x relay no 53 (to fit into relay socket 10 on fuse box)
Price is £20 plus postage at £2.50
(prevous feeler was priced at £20 posted but that was to a sepcific volume)
please note i have tried to keep as close as possible to original colours but some may be slightly different ie, white/yellow is white only
i only have one of these left at the minute but if there is more demand ill make some more!!
I accept no responsibilities for any damage caused due to this kit! All I can say is I have one on mine and use it nearly every day with no problems at all!
Edited by Pepe
  • Replies 12
  • Views 493
bump
hi mate, would these wire 6n2 ones? if not, would there be any chance of you making some up for me?
thanks
I would say no not this one but I can have a look and try make one up!
Does anyone know what plugs are on the back of the 6n2fogs???
Bump
hey mate, iv got a headlight switch with the front & rear fog function,
I'm not intending on using oem foglights, so using the switch i have, your wriing and a pair of fogs would i be ready to go?? :)
i could also be interested in a wiring kit for my 16v fogs dude.
althought i dont have a switch could i wire it up to a normal switch?
Indeed it would but you wound need to change the end plugs that go onto the lights!
yes you could connect the fusebox wire to a diff pin on the switch and have it working with the rear one!
I only have one of these left but if you both want one I will make another one up happily
yeah thats not a problem at all mate,
i were gonna use differnt fogs & mount behind grill behind mesh or somethin, stealth ;)
do the fogs get knocked out on full beam? & will the front fog warning light come on on the dash?
cheers
cheers
No fogs stay on with full beam! Ye the dash light will come on aswell as the rear fog if you have it hooked up to another pin on the switch! A switch with front fogs is about £10 so could be worth It the save abit of hassle?
I'm confusin myself lol,
my mums polos got a headlight swtich with front fogs, but no fogs on car, they're may be wiring there, ill check lol ;)
