Oil pressure senders: resistances?
I see many oil pressure senders on sale with their pressure range and thread sizes listed, but none of them have the range of resistances listed. Some say "will work with all gauges". Is the range standard? If not then it's no good using one brand's sender with another brand's gauge.
Also, VDO do 5 and 10 bar senders. If I were to use a 10 bar sender with a 5 bar gauge, would 5 bar still show up as 5 bar? So would a 10 bar sender have twice the resistance range of a 5 bar sender?
The same applies to oil temperature senders - they all list degree range but not resistances.
I could work all this out myself if I knew the resistance ranges, but I don't :)
  • Views 819
Well it looks like they're not magically compatible. I've just tried my VDO gauge with my Autogauge sender, and it works but the scale is quite badly wrong. At idle it's 0.4 bar on VDO (5 psi), with the Autogauge gauge showing 18 psi. At 2000rpm 1.2 bar on VDO (17 psi) vs 50 psi on Autogauge. So it's about 3 times out!
This is to be expected I suppose, but it's a shame! Now I'll have to buy a new sender and no doubt connectors to fit a different thread size :(
