project arosa - budget box
on saturday 16th jan i finally picked up sambo's old red arosa 1.0 for a bargain price, mot failure with 164k on the clock but most importantly was cheeep!
as expected the little red beast needs some love, so far i've sourced;
lupo gti front hubs / brakes with new bearings
gti arb
polo 16v seats
16v rear beam
going to look at some coily's later.
i need to sort some 14" rims to clear the new brakes too.
took some quick pics yesterday
Olly
  • Replies 279
  • Views 36.7k
got me bits today (19th), polo 16v seats, 256mm hubs with new vag bearings/ calipers + ebc greenstuff pads, 2 x 16v arb's, rear beam with built in arb from 16v and 2 x new front coilovers - sticking to the bargain bucket guidlines - paid £100 for the lot!
rear bench and 1 x arb not required so up for grabs.
Olly
fitted the brakes/ hubs up today (21st) and slung the bbs on too.
Olly
right lowered the rear earlier (28th)
when i bought it it already had chopped springs that were cable tied in place, this was the ride height
the main problem with chopping springs is when you jack it up the shock extends (as below) and the spring falls out or off the seat
this is the chopped down spring length just before it drops off the seat (no weight on it)
now i need to go lower (lower than coilys can manage either) so the springs will need to be shorter, the problem is i can't be doing with the springs dropping off everytime i jack it up, so the only solution is to fit shorter shocks
as you can see the travel isn't much shorter but the overall length is reduced
these shocks are not vag items and the bottom mounting is narrower than the arosa items, so a 4-5mm spacer is needed
this will need to be fitted in the inner edge of the beam
i lopped a bit off the springs (not alot - you'll se why at the end) that were already chopped down
with both shocks and springs fitted this is the length of the spring in place under 30+ mm of compression but the wheel off the ground just the shorter shock compressing the spring and holding it in place
so now this is the tyre to arch gap with the wheels off the ground and the shocks fully extended
now i could go another 20-30mm drop in the following pics but as you'll see i need more wheels before i do that
Olly
i decided to strip out the rear trim earlier (29th)
if there's any trim in the above pic you want just let me know
also srtipped the cards off
next part to be removed was the rear seat mount, i drilled out all the spot welds
and pulled it off
thats all for now
Olly
done 150 mile round trip today to pick up a few bits for budget box - £270 later (keeping it cheapo) this is what i got...
hopefully start getting the 1.0 out this week and clean the valver up.
Olly
:thumbsup: sum good progress
another mag feature :p
awsome mate, love how you just get on with stuff....looks like its gunna be an interesting little beasty!!
thanks chaps - it's just a bit of a fun project - been thinking about some custom diy bodywork, diy paint etc etc nothing expensive.
i'm hoping to keep it all below 1k hence project budgetbox - including buying the car i'm upto £505 so far.
Olly
love it :)
looks awesome mate, that should go like shit off a stick when its all in!
cant wait to see it develop!
including the car ... you have tht the engine, box and all the other lil bits and youve only spent £505.
cant wait for the updates .... i cant beleive you only spent tht much. lol
Edited by parfay_2009
love it mate! love to do sumit like this one day :)
For a 'budget box' it's pretty damn nice man :p
Alex
thanks chaps, i want to get the engine in and start customizing some bits on the body.
Olly
i love these lil lupo's me thye so cool this 1 should be rather nippy
Its an arosa ;)
Looks like a good project, look forward to seeing it finished :thumbsup:
thanks chaps - lupo/ arosa same thing really, been thinking about putting a lupo front on it or doing a Kam/poundie 6n polo look front on the arosa......
Olly
Olly
good call....that would be a first surely??? have you got any pics of an extended bonnet on an arosa?
Nice, can't be many Loops/Arosas with an AFH in them!
quite a cool little project to test ideas on you might have been to scared to try on some of your more expensive cars
I love reading you are threads! :)
thanks chaps, i don't have any photo's of an extended bonnet just a quick photochop but not sure where that is.
anyway got home from work at half 4 and started doing some bits
by half 6 i'd got this far and packed all the tools away then i had to weld some subfrmes to corsa bucket seats for a mate.
Olly
You've got skills mate
On uni mac so did a chop
DO ITTTTT lol
haha i did consider pickup'ing it!
Olly
