Changing Headlights help.
hello. i dont have a hayes manual yet and my new headlights came today how about would i go fitting them i know theres 2 star keys on the top of them, where else are the screws and do i have to remove front bumper?
thanks for help
  • Views 1.5k
It's easier to remove the bumper and undo the bottom screw on the light! It can be done without taking it off but it's tricky!
I found if u take the 2 top ones out and get dome on to pull up on the light and push down on the bumper u can just about get a small extension in the gap
As Pepe said its a bumper off jobbie.
I attempted to change mine without taking the bumper off but had no luck in getting an extension in the gap to undo the third screw under the headlight :(
Edited by DubSingh-Dhali
I did it with the bumper on, i just did a nice curve with the angle grinder to get to the 3rd bolt ;) Made sure it wasn't noticeable when the light was put back in.
Is this on a 6N?
It's been three years since I changed my headlights for Powerlooks so I can't remember what tools I used exactly, but I never had to take the bumper off?
Was probably just a long thin screwdriver/extension.
I don't seem to remember it being a difficult job at all though, can definitely be done with the bumper still on. Just need the grille surround and indicators out the way.
Edited by Tris
Yeah 6n, two torx bolts on top, then i cant remember if its a phillips of torx bolt in the middle at the bottom through the little hole, defiantly a long thin driver.
Fuck taking the bumper off :p
