MK 3 LooN ! How W-I-D-E Can I Go ?
Thinking of bying a mk3 loon and was wondering what width wheels i can fit under the rear arches ? some body help ! i dnt want to buy wheels which are to wide and get fines thts all ! :? thanks ...
theres a pic of a loon with stefan evos on it in the wheels for sale section
8s and 9s i think he had on there take a look
Pretty sure the rear arches are exactly the same as the coupe. so I guess anything that fits on one should fit the other.
The rear will sit around 15-20mm lower if youre relying on the same suspension as a coupe though.
the 8j and 9j you are refering to bud are on a bmw not a polo so as i previously said in the other thread i wouldnt go wider than 7j
there are too many different variable to be able to say 'don't go wider than 7j'. I've seen 7j wheels that stick out further than some 8j's.
Width is a major facter but the offset of the wheels is just as important (probably more important tbh). I had 8j's on the back of my old gt and they fitted perfectly because they had an offset that suited the car.
Its the front wheels you need to be careful of mind, the track is wider on the front so its best to go with staggerd widths/off sets to get the front and rear wheels sitting nice in the arches.
13x7 ET20 and 13x8 ET0 always worked well for me.
