Central locking real slow and sometimes doesnt work...
Any 1 have or had a problem with their central locking? on my 6n when i press the key fob button thing sometimes it does nothing but the light on the key fob lights up, and when it does work its really slow :/
new pump?
If i got a new pump would i have to reprogram?
  • Views 1.2k
Well yer by the sounds of it you need a new pump mate
Is that coz you are selling 1 :p i would buy yours but skint till 2 weeks time :/
Na its not that its because if it was not working at all it my be the fuse but due to it only working now and then and when it does the pump is slow then you no that the pumps on its way out
Are you sure that there aren't any air leaks on the system.
The only way that I know of for checking this (apart from listening for leaks) is to disconnect the pipe from the pump and blow down it by mouth. you won't unlock the doors, but you can detect loss of pressure.
Regards.
