fuel tank and front wing
hello peeps...
iv got 2 polo coupe genesis and I'm trying to swap things around to make one good one ( my project for the winter )
i need to swap over the petrol tanks and change over the drivers side wing ( front )
can anyone help with useful info or pics and descriptions or so..
..also how easy is it to change the front shocks and springs over??
any help would be wicked
thank you!!!
  • Views 812
I would invest in a haynes manual. It some times can be a little bit off but will cover everything you have asked and there are some good diagrams.
Front wings are ok. there are bolts at the top under the bonnet, 3 inside the wing near the drivers door underneath loads of sealer. and 2 screws at the bottom of the wings
Petrol tank is trickier. its simple but a pain in the arse.
Its easy just to swap the front struts. just remember to loosen then nuts whilst the car is on the ground especially the drive shaft nut.
sweet mate....i think i know what you mean!
might get someone else to do the fuel tank - might just get a new one rather than swap
shocks seem simple enough...
nice1
