Pedal Box
As stated above would like a Pedal box that has the brake light switch on the pedal box
must also not be to far from Birmingham as I'm not using paypal as I got shafted a few months back
cheers
Melon
  • Replies 12
Bump still need of and back on paypal
Have one at Cosford, off work at the mo so wouldn't be able to remove it till the weekend
Sweet I hopefully have my car back on the road this week and be able to come collect hopefully fingers crossed
Still after one cheers
Got one up here in Manchester. Not sure it has the switch attached, but it's from a J reg GT squareback. It's quite a heavy thing So I'm thinking around £15 posted
  • 11 months later...
It's been a while since I look at my polo since it broke down in march but i've start and it going to make it it's first polo slow even if it's in primer.
You don't happen to have the pedal box still.
Mk.2 and Mk.3 pedal boxes are different.
Is it going on a Mk.2 as per your avatar?
I should say Mk2 or Mk2F
I have a very early mk2 pedal box. I reqiured a MK2 loom with the brake light wiring for the brake light switch to be located on the pedal box but the early one don't have the hole to have the brake light switch on the pedal box.
At the moment it running a wire from the battery with an inline fuse to the brake light switch on the master cyclinder then running into the car and cut into the rear wiring loom. (How I got it)
I would like one to make it tidy.
I got to make a real effort this year to get this baby going again.
Edited by residentmelon
Still got the mk3 pedal box. In fact I have two! But presumably they are slightly different to the mk2 as the mk2 doesn't have a servo.
So you need an '85 - '90 pedal box then ;)
You going to the rolling road day?
Yeah looks like I need a 85 - 90 pedal box.
Not sure if i'm going but I do work in Derby and going to Nottingham this weekend if you got one I could collect.
I'm sure i've had something of you before aswell
Yeah, I got a couple.
Will be at the unit tomorrow afternoon and Sunday afternoon.
