6n2 Gti Ignition Wire Diagram?
I don't suppose anyone has a wire diagram of the ignition system for a 6n2 Gti?
  • Views 9k
what're you needing to know exactly?
I've bought a Start Button for my car that when you put the key in the ignition you can press the button to start the engine instead of turning the key. But I dont want to go playing about with the electrics as I'm not familiar with it and i will most likely bugger it up!
http://cgi.ebay.co.uk/ENGINE-START-IGNITIO...=item3361344098
I need to know which wires i need to connect because I've got a sort of diagram with the button but i wanted to have a diagram of the ignition system to help me...
Hope that makes some kind of sense :)
The Haynes manual doesn't show any differences between the GTi and other models for starting. According to their circuit diagram the start wire is red/black and the feed to the ignition is red. Both wires are easy to get at under the steering column. Remove the lower part of the cover, torx screws from the underside, the back of the ignition barrel has a plastic shroud which un-clips, the wire travels down the column behind a trunking, the top un-clips to get at more of the wires.
If you just connect your switch across the ignition it will work, but you will be able to operate the starter without the ignition being on. If you don't want this to happen you'll need to fit a relay to inhibit the start switch until the ignition is on. The black wire from the ignition is live in the on and start position so could be used to feed a relay. As with all things from books, please check the wires with a meter before connecting.
Thankyou, I will try this as soon as i get some time and try to remember to tell you how it goes :)
Done! :D
Before...
and after... :)
Thankyou so much.
