6N / Ibiza dash parts for sale
Following a failed dashboard experiment I have the following bits for sale.
From a late spec 6N Polo: -
Headlight switch with range adjuster £10
Drivers side air vent. £5
Passenger side vent (bottom wheel is missing). £3
Heater control surround panel. £5.
From an Ibiza, as far as I know all this lot will fit a 6N Polo: -
GTI Dash clocks - red illumination, orange text and needles, 150mph speedo, 7k rev counter. £40 SOLD
Clock surround. £10
Headlight switch (red) with range adjuster. £10 SOLD
Headlight switch (red) for front fog lights, NO range adjuster. £15
Steering column/ignition switch surrounds x2, one is for adjustable column. £10 each.
Dash speaker grills (pair), no broken clips. £15
Drivers side air vent x2. £5 each.
Passengers side air vent. £5
Drivers lower glove box. £10
Passenger glove box and lower shelf, complete. Shelf has 2 small screw holes in it. £15 SOLD
Lower shelf for models with passenger airbag. £5
Electric window switches (red) with panel and blanks. £15 SOLD
Airbag warning lights x2 (1 early,1 late). £3
Heated rear screen switch. £5 SOLD
Switch blanks x4. £1 each.
Screen vent trims x4. £5
Centre console pocket/cubby things x2. £5 each.
Gear stick surround. £5 SOLD
Ashtray. £5.
Centre console trim, there is a broken screw hole bottom right, and the heater control part also has 2 broken screw holes (can be seen in pics). £10. SOLD
Alarm/immobiliser units, 3A0 953 233 C & 1H0 953 257 B. £ Offers.
I'm happy to provide individual pictures or part numbers on request. All prices are open to negotiation, particularly if you're after several items. Also I must add none of the electrical items have been tested.
All prices include postage.
Thanks for looking.
Edited by Puncharado
  • Replies 16
  • Views 627
will the Ibiza dials fit Directly into a 1998 Polo 6N???
Thanks Matt!
I believe they fit and plug straight in, but as I haven't tried myself I don't know 100% if they will work correctly. They also have the MFA display, which I'm pretty sure won't work on a car that doesn't already have it.
Offers welcomed on everything, needs to go.
Alright bud how much for: Headlight switch (red) with range adjuster, Electric window switches (red) with panel and blanks posted? also do you have any other switches in red? such as rear heated window switch, or the heater controls? cheers
Do you still have the glovebox and the gear stick surround?
Cheers conor
You have the newer style gti clocks so there a straight for into a polo 6n with newer clocks same with my Ibiza gti clocks I have for sale they fit directly into the older polo.Just a heads up
All still available.
L4 Dub - Yes, I have 2 Ibiza rear heated screen switches and 2 airbag warning lights, but not the heater controls. Will do the Headlight switch (red) with range adjuster, Electric window switches (red) with panel and blanks, a heated screen switch and an airbag light (I have 2 different types - your choice) for £25 posted.
Connor - Passenger glove box? That and the gearstick surround, you can have for £20 posted.
Thanks.
Passenger glove box and gear surround sold, all other items still available.
Any reasonable offers will probably be accepted :)
Thanks.
Hey really sorry about the delay my laptop decided to die so i couldnt get on the internet, if you still got those bits i will have them! the only part i dont need is the airbag switch as i have the later spec 6n so airbag light is in with speedo. If you still got everything else send me your paypal addy and il send the money, cheers
do you still have the interior grills. I'm after the left one in the centre, that sits above the head unit
cheers
cheers
I'm not willing to split the vents from the surround, I only want a tenner plus p&p for it (see 1st post), so £15 'cos it will need a fairly big box. PM me if you want it. If you want anything else on top postage will be the same :-)
Also headlight switch (red) with range adjuster, Electric window switches (red) with panel and blanks, and heated screen switch are now sold.
Centre console surround with vents now sold.
Don't be shy with the offers, I want to shift this stuff after all. It'll look better in your car than it does sitting in my loft.
BUMP.
PM'D :)
Ibiza clocks now sold.
Any offers on what's left?
Brilliant seller, good contact and got the clocks the next day :D well happy!
Cheers again mate.
oh and BUMP
