dewiper 6n instructions
below is a guide for removal of the rear wiper on a polo 6n. but will probably give a rough guide to all models
This is how i done it and is only a guide. i can not be held responsible if you fail to carry out the task and brake something in the process.
To disconnect wiper and remove it
just remove the arm, one nut at the base under a cap, remove plastic from inside of tail gate just clips off with a few "pops" then you have to disconnect the wires very simple also. last your find a few nuts holding the motor on remove them and it slides off.
To fill the hole
you need to keep the little rectangular shape plastic surround with the hole cut out which your see. below is an illustration.
circled red is the bit you keep from the wiper assembly
green is a rubber grommet
you will need a rubber grommet to fill the hole in the plastic .
The grommet is the easy way only taking up to 20-30 mins. just push it in the hole then glue the surround to the window . done
grommets can be found here not sure what size it was but all you got to do is measure the hole
choose a blind/closed one there only 99p
http://cgi.ebay.co.uk/2-x-Rubber-Grommet-O...=item6b1b011260
or
or if your handy with a little fibreglass, filler and paint you can fill the hole that way.
If you choose to smooth the hole this will take you a little longer but your work will pay off. it will look a lot better smooth and with a quick coat of matt black
  • Views 741
