How to: fix your wobbley seats.
Thought id write a little guide on how to fix your wobbley seat bases.
Things needed:
10MM spanner or rachet
Center front guide pieces- X2 part number 435 881 203 A
Outer guide pieces, - X2 part number 171 881 213 B 2VK
Inner guide pieces - X2 part number 191 881 213 909
All these are avalable from your local dealership and cost about £10 - £15.
First of all you need to remove the front seats, this is done by taking the bolt out of the runner - located at the central front.
Once you have this out slide the seat all the way back, and now the seat will lift out.
Now once the seats out of the way, you will see one of the guides that pushed in to the chassis (mine was missing which ment you had to wiggle the seat to get it to lock), just prize this out and pop your new one in, make sure you get it the right way round.
Heres a pic to help explain what mean.
Now you need to flip the seat up side down, and you will see the clips on the back corners of the seat, these are sided and will only go on one way.
Pop the old ones off and care fully slide the new ones on until they click in to place, if they are stiff to go or dont click in to place you probably have mixed the outer and inner ones up.
These pics show the guide pieces you need to remove.
And heres one to show the new guide piece fitted
Now its just a case of putting the seats back in the car, simply locate the back of the runners and slide the seats forward, while you locate the locking pin handle in to the pin, refit the little bolt.
Now you should be left with wobble free seats that slide back on forth easily.
Time for a sit down :).
  • Views 5.2k
cheers dude, got a gt one i`ll put on soon at that wheels well tatty :lol:
Passengers seat subframe does that. Just shoved an Allen key in the runner
