Mk2 Polo Coupe S Loads of extras and reciepts
Vw polo coupe S, 1989 F reg, 1.3 rustic satin blue, 6months tax and mot
build thread from when i got the car:
http://www.clubpolo.co.uk/forum/index.php?showtopic=244129
the body has done nearly 183,000 but the engine has only done 60k and i have receipts of a full service history. the car has only been on the road for 6 months and i have only done 4k, all electrics and lights work
head has had a skim, new payane head gasket, head bolts, new gates timing belt, water pump, its had 2 oil and filter changes and 2 fuel filters and air filter in the last 4k, spark plugs, ignition leads, dizi cap, rotor arm, ignition coil and new connectors fitted, fuel pump, red anti freeze put in, new gearbox oil, rocker cover gasket, inlet and exhaust gaskets, engine management temp switch, thermostat, expansion tank cap.
body has had all rust removed, all underneath has been under sealed, 2 new track rods and an end, number plates, pedal pads, winder handles, throttle cable, clutch cable, wipers, brake light switch, brake fluid, brake shoes, cylinders, shoe fitting kit, o/s cv joint, front pads, fitting kit, top mounts, o/s wheel bearing and a new battery and all new fuses.
the modifications are new 40 grooved disks, g40 brakes, new suspension all round, 80mm springs and sport shocks, solid anti roll bar blocks, mk1 golf gti splitter, de badged boot lid, rear seats have been removed and carpeted the floor, sub woofer box behind seats, porsche 944 seats and steering wheel, full exhaust system with micron bike can and poly bushed track control arms.
also with the car 600cc bike carbs, GT head, 300 degree cam, dbilas vernier pulley, spare MH bottom end and rear goodridge hoses.
car does NOT come with stereo, porsche handles and porsche floor mats
I'm asking for £1200 ono
call me on 07901050101
location is Bangor N.Wales LL554ES
300" cam :0
vernier pulley
gt head
carbs
Edited by wideboi
  • Views 1k
swaps for my gt?
swaps for my gt?
no thanks bud. I'm looking for sum thing a bit bigger
receipts. and lots of them
more pics
bttt
fitted new alt belt yesterday. cold air feed fitted to the fog light. more pics up tnite.
hiya would u be intrested in a swap for polo 9n 1.4 16valve 3 door grey tat
