"Chrome" window trim
So, my mk2 saloon has the "premium" window rubbers front and back with a "Chrome" plastic strip running around the inside.
I've removed the old, corroded chrome strip in the hope that slotting the new one in would be nice and easy.
It's this stuff: http://www.golfmk1.co.uk/Details.php?item=...ALS&cat=ALL
How wrong I was. I can't get it back in no matter what I try. I'm now angry. And wet (it was raining). :retard:
So... has anyone here done such a thing before, and if so - what's the trick?
Major kudos to anyone with the "right" answer (one that doesn't involve removing the window!). :thumbsup:
(If the ONLY answer is to remove the window first, please let me down gently).
Edited by louisv6
  • Views 2k
if there is a will there is a way now :), i had the same witth my classic mini what you do is stick it in a bucket of boiling hot water, and i do mean boiling kettle hot, then itll be nice and soft, then you need a little tool like this one
http://www.dugdalevms.com/www/images/Winds...0Seal%20003.JPG
start at the bottom in the middle and work your way around
then when your finished boil the kettle again and make yourself a good cuppa grab a biscuit and admire your loverly work
hope this helps dude :)
Yes - just the kind of helpy information I needed. Thanks for that :-)
So I guess I need the "Insert Trim Tool - Plastic Trim" listed here:
Status-vw.co.uk - Deluxe Model Seals
I can cope with that price...
right you are :) good luck man :)
Found a good how-to video if anyone's trying to do the same. Will be trying it out today.
http://www.brick-yard.co.uk/forum/fitting-...topic64691.html
Worked a treat.
Used WD40 to lubricate the rubber and then used the tool to get it in as per the video.
WD40 cleaned off easily with bog standard window cleaner.
