6n Side Repeaters
Typical noob question, but how do you remove the side repeaters? Push towards the back of the car and lever out like most?
TIA
  • Views 2k
Side mounted turn signals
Removing and installing side mounted turn signals
Removing:
Note:
Extreme caution must be used when removing the side turn signal as it is only possible to be removed in one direction and it is not possible to recognise which side of the turn signal the spring clip or the mounting sits.
When using force to remove the light on the spring clip side there is a great danger that the turn signal or the vehicle paintwork surface will be damaged.
‒ → Press turn signal with a suitable tool on the mounting position side -1- carefully in direction of arrow against the force of the spring clip -2- on the opposite side and lever out (protect paintwork surface with adhesive tape first if necessary).
‒ Pull rubber holder with push-fit bulb off bulb housing.
‒ Pull push-fit bulb (12 V/5 W) out of housing (do not turn).
Installing:
‒ Fit rubber holder with push-fit bulb onto bulb housing.
‒ Insert turn signal in wing.
‒ After installing a new bulb check function of turn signals.
Excellent job, thank you
