Uprated Front Radiator Brace Bar
I had one of these fitted to my G40, after a few enquiries about them i decided to have a batch made.
The are made from mild steel 3mm thick, zinc plated.
They have all the holes for mounting to the chassis, holes for the radiator and the holes for the intercooler on the front.
If you have ever had an original front bracket off you will see how weak it is, this bracket strengthens the front a great deal, help stopping the dreaded chassis flex.
All in all a great addition to any mk3 polo.
Fitment is a simple task, please note these brace bars can not be fitted with the standard plastic radiator cowling, the cowling will require modification.
Originally had these up for £40 but now only want £25 each, postage will be £8 courier
  • Replies 11
  • Views 631
Any chance you can keep one till the end of the month?
I've got a fair few of these mate but yeah i will make sure i hide one for you :D
would this fit a mk2 or are there differences there?
id say there will be a difference, etka says different part number. Worth a look if you have an existing one tho to check
The mk2 set up is different. The valance makes up part of this piece.
Thank You DK.
thanks for the info - i cant just go and look at my car as its 160 miles away. :)
  • 3 years later...
Any of these left?
Any of these left?
I don't think DKnight sells them anymore, I have a used one for sale if that helps
One of the uprated ones? Would you post it?
Yep, one of uprated ones and I can post. Drop me a PM and we'll get something sorted
