Cutting and welding oil pick up
Unfortunately i have a late afh and i want to go low so inevitably i have to modify the oil pick up, i can chop it and weld it no problem, just not too sure how atm, anybody else done this?
Nice one.
  • Replies 46
  • Views 4.2k
  • could always measure the depth of a early pickup... or i could just spoon feed you the info if you like? looks to be 120cm from the main bearing cup to the tip of the pickup (give or take a
  • harris.racing
    harris.racing
    With getting measurements wrong like that guy - it's no wonder all the ladies are after you
So your using mk3 sump but cutting the pick up down right?
Correct
I dont understand what bit you cut lol
Why cant u just hack the bottom off and leave it?
I don't know, maybe you can, thats what I'm trying to find out
i cut down my pickup on the late AFH and had it silver soldered/ brazed up at the right height to fit an AAV sump,worked a treat.
Edited by mini_mayhem
How and where? lol, got any pics?
i've gotta do this in the not too distant future. it's no real help to you now but i plan on testing some weld on a scrap piece of the pipe and if that works out then i'll weld it, if not i'll be getting it brazed. i can't see any reason that it wouldn't weld ok tho as long as your careful not to blow the fuck out of it as it is fairly thin if memory serves
Brazing is easy
tig it?
You got any pics of how it looks guy, i don't even know what it looks like yet lol
Edited by MoustacheG40
Ben Polomon has already done this and did have pics in his build thread but it is no more :( unfortunately
ask him thought but i did see pics and it does look straight forward
Ok nice one. will do
Tig will be best dude.
Ben didn;t do it in the end, he raised his engine instead :-/
You can just see it in this picture lol.
Not great but you know, only pic i could find of mine
Edited by B-shaw
Ill whip it off tomorrow and assess the situation
You don't need to cut anything, only need to bend it.
First the support arms, there straight like your arms when you're about to start doing press ups. They need to be like your arms when your nose is near the ground.
Then just bend the two bends a few more degrees each.
All you need is s blow torch to soften the steel, well you might do it without, but it'd be easier to do a good job. Wash it out with petrol first, so you don't get burnt oil flakes in there.
like you say this is really only an issue if you've got the later AFH bottom end 98> as it uses the oil pump driven directly off the crank, early ones use the chain driven pump like on a mk3 polo, so you can just swap the pickup pipe over to fit a mk3 sump.
I have had both bottom ends, and just shortened the pickup pipe and TIG'd it back together, i just measured the difference in sump depths and cut the relevant amount out.
luckily my current 16v bottom end has the older style pump which did make life a bit easier
Edited by gofasterpinch
Shortened mk3 oil pickup... i iwll run it Brett, i just aint doing yet. ;)
That's the wrong sort Ben, Brett's on about the late spec one which is totally different
Ben shortened a short pickuP haha
Ye i read the post, we had a conversation about it. Just thought i'd add a picture to back up last nights conversation.
:-D hahahaha.
Haha, we did to be fair...
Ill see what i can do then Mikey, nice one :thumbsup:
Pulled it off today, it's i don't think bending it will do the trick, it won't give me enough room. i've gotta cut it, but i don;t want to take too much off. I need to know by exactly how much the mk3 is shorter than the afh?
It's literally the length of the cone that is different isn' it?
capable of 2" front engine lift, 1" rear..... on 8v anyway..... how much more sump clearance do you need?
