Chris Pinches mk3 Rally Project
Model: 1991 Polo CL
Engine: Original AAV, K&N filter, oil cooler, oil catch tank, poloace chip.
Suspension: Home-brewed front coilovers, avo inserts with 140lb coilover springs. rear bilstein tarmac dampers with 100lb springs
Brakes: G40 Front discs and calipers with raicam pads
Wheels and Tyres: 13x5.5J "Tarantula" wheels, 185/60/13 Avon ZV1 or 175/70/13 Dunlop SP85
Exterior: Big black mud flaps, Cibie super oscars, Gt arches
Interior: Magnum pro sport bucket seats, Luke 3" FIA 4 point belts, plummed in extinguisher, OMP steering wheel, OMP navigators footrest, Gt clocks, Flocked dash, "works" centre console with extra guages/switches, Quaife gearknob
ICE and Security:erm....no ICE, and you need a key to get in...also has FIA master cut off switch
Comments: still a work in progress. i am looking for a road car so i can get on with this as a project. over the next year i hope to have it caged and some of the shell stitch welded and hopefully some more power. Hope you like the pics:
  • 3 months later...
  • Replies 180
  • Views 50.4k
  • Guest vdub13
    Guest vdub13
    yep thats my car. she has been getting a make over lately!
Lovin it, thinking of doing something similar to mine...
way hay recconise this from another forum 8-)
Nice work with this Pinchmaster. You know the zantvoorts are the best on this!
Looking forward to seeing the changes now you've got a *eww* mk4 so you'll have to keep us informed, k?
haha, well, so far-
new interior
featuring hydraulic handbrake
hi m8 :) where did u get that air intake system from? cause mines got the big round system and id love to change to something like that so i can hav a cone filter on ,thanx matt.:)
that air intake system is from a mark3 golf, I've got the same on my polo too :D
sweet u jus reminded what 2 use all that crapfaabric 4 lol!!!!!
tbh tho mk3 dash is much better to use than the mk2!!!!lol
i really carnt w8 to get my mk2 done now!!! (running a std 1L atm shoud i do an engine swap??)
Edited by mk1poloblade
that induction kit looks a bit weired IMO, a bit like a light saber !!!
(homemade !) lol
Edited by polokid
I just think it looks like a *censored*
I like this car as it shows us what it's like to do something many of us wouldn't want to do, but would like to if it wasn't for the minor problem it might cause in daily life.
might look weird, but it works. i'd rather have nice cold air coming in through that hole in the inner wing than just inducting hot air off the back of the engine.
nowt wrong with a bit of home engineering either!
did'nt say there was, cool little project differant !
  • 3 months later...
anyhoo, ignoring the posts by polon00b, I've made a bit of progress in my "Blog"
first off, some stainless bolts on my ARB blocks, and also my ARB clamps zinc'd (thanks to spaniel for hooking me up)
really wish i'd got the plates done now aswell, i think i will take them off and take them back with me to get done as they seam to let the whole setup down! or i may remake them in stainless....**ponders**
i also fitted my new stainless bolts into my Vernier pulley i made
then i cracked on with fitting my spotlamp brackets!
designed and made them myself from 6mm aluminium and TIG'd. these should allow me to run 4 spots in a 2up 2 down fashion, although some bumper choppage is required! i think I'm going to get the brackets anodised black as they're a bit bling for my liking.
thats pretty much it recently, i discovered today that the tin panel that the rad sits on is proper goosed, so i think I'm going to make a new one from 2"x1" oblong box section and get it powder coated :unibrow:
i also finished stripping out the back
and a random front end shot before i kicked off today
finished chopping the bumper to clear the spotlamp brackets today
now i just need to finish rebuilding my spotlamps and get something that will actually hold my front number plate on, rather than it falling off on the first corner
so, i went and robbed some M8 bolts from down the unit and refitted my spotlamp brackets
then i set about making my grille "race spec" by adding some speed holes
this is to allow more air into the engine bay, especially when I've got my big spots fitted they block off alot of the grille.
i then started fitting my quick release twin spare wheel carrier. started by drilling out the spot welds
then gave it a bit of adjustment with the worrying stick, followed by some wiggling by hand to break the remains of the welds off
shazam!
trial fitting of the twin wheel carrier.
followed by some tin bashing to level out the floor so i can bolt it in, and were good to go
really pleased with the outcome of it, looks really good and is really quick and easy to use. i then set about fitting the genuine VAG first aid kit and holder i got off spaniel
looks pretty good i think. i spent the rest of the day tidying up the garage and trying to fix one of the tube lights which just stopped working. oh and i also ditched a couple more bits of interior trim (door bins etc etc)
nice work pinch face. bet youll be lookin forward to havin a flat tyre now!
haha yeh cant wait. although i haven't got a jack at the moment which might be a bit of an issue :lol:
some more pics of the whole job
do u drive this every day?
used to, but not anymore
Looking nice. I really like it. What are you doing about power wise, are you going to stick a bigger lump in there or you keeping the AAV?
Keep us updated
Scott
AAV will be stopping for now, unless the right engine comes along at the right price. tbh i'd rather spend the money on a decent box with a diff and big shafts then get any more power yet
Thats cool. What do all the switches do, were the center consol goes?
something like this
cool matey
you can go lighter ! :-)
handbrake hard to fit ?
buzz
I fancey some gauges in mine, I take it spots are your uber big lights on front, whats POTI? And the rest do?
