Fitting new electric window mechanism
I'm hoping someone on here can help
Just had to buy a new electric window mechanism for my 2001 polo and I haven't a clue how to install it.
Anyone help?
  • Views 861
Door windows
Removing and installing window lifter
Removing
‒ Remove door trim and door insulation sheeting.
=> General body repairs, interior; Repair group 70; Door trim; Removing and installing front door trim
‒ → Pull inner window slot seal off -1- flange.
‒ Crank door window down and unscrew door window.
‒ Tilt door window towards front and lift out of window slot.
‒ → Unclip clip -arrow- for Bowden cables.
‒ Loosen hexagon head screws -2- (10 Nm).
‒ Lift window lifter slightly so that hexagon head screws -2- can be pulled through installation openings.
‒ Separate window lifter motor connector on vehicles with electrical window lifters.
‒ Pull window lifter out downwards through installation opening.
Installing
‒ Install window lifter and adjust door window =>Page 64-35 .
Door windows
Adjusting door window
Door window screwed lightly to window lifter.
‒ → Crank door window upwards or downwards until clamping jaws are located in the installation openings.
‒ Loosen clamping jaws, push door window into window channel -arrow- and with hexagon nuts -1- (10 Nm) tighten clamping jaws
magic mate cheers for your help ... again! :)
the window at the moment is chalked with a piece of wood in the closed position. is it easier to install in that position or in the lower position?
lower position to be fair mate
