blaupunkt pull out cd player
I run one of these in my g40 and I have to say it is a pretty good unit.
blaupunkt acd 9431 in full working order
4x8 watt rms output (pleanty loud enough)
4 channel pre-out, so you can connect external amp to it (an additional iso plug is need for this though and is not supplied by me) link to required lead below:
http://www.ebay.co.uk/itm/Autoleads-PC3-10...=item518b1d56db
+- 7bd bass control
+- 7bd treble control
balance and fader controls
cd player will only play regular cds, cdr, cdrw, won't play mp3s
radio works well
correct radio cage supplied
code supplied, but I have turned the code off, so unles you turn it back on, you won't need it
print out of manual included
rare and hard to come by unit that looks exactly like the oem headunit, only it has a cd player instead of a tape deck!
An absolute must have if you are into oem+ modding
£75 posted 1 class recorded
£65 collected from chipping norton oxon and I'll even fit it for you if needed providing your original loom hasn't been hacked to bits. you will need to buy an iso male to female connector though, like this:
http://www.ebay.co.uk/itm/Male-to-Female-I...=item3cb8b4fec9
Edited by g40jon
  • Views 296
